Vacuum Secondary spring kit - Team Camaro Tech
Old Jun 14th, 10, 04:02 PM
johnny5 johnny5 is offline
John
Default Vacuum Secondary spring kit
Picked up a kit and started messing with an old 3310. The short yellow spring just appaers to be clipped is this the way it comes from Holley. Anyways the lightest spring works fine as I thought it would since I can run DP on my car but the 3310 definately has more bottom end grunt where the dp really shines up top.( kicks the 3310)
Does anyone have the spring kit and is that the way the short yellow comes? It says not to clip the springs in the instructions.
Thanks in advance.
John
69 Coupe: 350, KB Pistons, 750 DP, AFR195s, RPM air gap, Comp XS274S,Turbo 350, TCS 2500-3000 stall, Hooker Super Comp 1.75", Ford 9" with custom Moser axels, 3.90 Posi, MSD digital 6, Hotchkis springs, 4WDB
Old Jun 14th, 10, 06:32 PM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: Vacuum Secondary spring kit
Yes, yellow spring is made this way. Reason to not clip the spring is it makes it stronger/stiffer.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
