Upper control arm bolt fell out - Team Camaro Tech
Old Jun 16th, 10, 05:51 PM
jsouthco68camaro's Avatar
jsouthco68camaro jsouthco68camaro is offline
Jim
Default Upper control arm bolt fell out
So I noticed a change in my steering yesterday and started looking around. I found the passenger side upper control arm had the forward bolt missing. It wasnt there at all,.... There isnt anything on the front side of the arm but the bushing. I assume it is missing a cup washer and the bolt... Can anyone tell me where I can get a replacement and / or what size the bolt is?
Can i just reinstall or does this adjust the castor /camber and is more than just putting the bolt back in?
I think this is one of the few areas I havent touched yet on the Camaro..Time to learn something new..
Thanks for any help!!
Old Jun 16th, 10, 06:21 PM
vincevs's Avatar
vincevs vincevs is offline
Team Member
Vince
Default Re: Upper control arm bolt fell out
I used the poly super kit from PST for my front end. I even lost one of the bushings and they sent me another for free. Great customer service.
http://www.p-s-t.com/pc-3785-30-chev...o-1967-81.aspx
Vince
67 rs/SS L48 4spd Convertible
Options; Build Thread
Old Jun 16th, 10, 06:37 PM
Steiner Steiner is offline
Steiner
I believe it is a 3/8 fine thread grade 8 with a lock washer, somewhere between 1" to 1.5" long. You can get them from Ace or somewhere with decent bolt selection but the cup washers usually have to be purchased as a set of four. If you use a little LocTite on the threads and use suspension grease between the cup washer and bushing it helps. What happens is that sometimes they'll bind together and with the arm moving up and down it will back it out. The grease helps. You should be able to get it back in with the front end jacked up a little and the tire removed. It may take a pry bar if it shifted.
Bolts and washers here:
http://www.rickscamaros.com/camaro-c...1967-1969.html
These are five bucks but I don't know if they're correct or not:
http://www.drclassic.com/catalog/Cam...re/T00328.html
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Jun 16th, 10, 07:00 PM
Jim
Thanks for the responses. It doesnt look like it shifted so it should be pretty easy to get back in.
I appreciate the help.
Jim
Old Jun 16th, 10, 08:54 PM
Red Rocker Red Rocker is offline
Bob
http://shop.stevescamaroparts.com/67...kit-029173.htm
" Some like it Hot, I like it Red "... Sammy Hagar
'69 Coupe...Red of course!
http://i1243.photobucket.com/albums/...anGregorio.jpg
Old Jun 16th, 10, 09:11 PM
K and K K and K is offline
Kevan
I have those parts from my stock shafts that I didnt reuse. I can send you a bolt and washer if you would like?
67 RS 4speed Original
(I haven't changed anything that can't be changed back)
Nicole: http://www.camaros.net/forums/album.php?u=42213
My build thread: http://www.camaros.net/forums/showthread.php?t=160602
Old Jun 17th, 10, 04:55 AM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Loc-Tite on the threads or safety wire the bolt heads.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Jun 17th, 10, 05:06 PM
Jim
Kevan,
I appreciate the offer. I went today and got a bolt and washer from Ace to get me through until the weekend. We have the "Back to the 50's" show in Minneapolis this weekend and i am sure I can find what I need there.
Jim
Old Jun 17th, 10, 05:28 PM
novaderrik novaderrik is offline
just use a grade 8 fine thread 3/8" bolt and a washer from a sway bar end link.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Jun 17th, 10, 08:48 PM
GR8_68 GR8_68 is offline
Sean
I had problems with with my control arm shafts loosing the retaining bolt and allowing the poly bushing to squirt off. It happened twice, so I finally replaced the control arm shaft with a much beefier one from Globalwest Suspension. The replacement shafts have threaded ends that accept a washer and a nut. Much better than the threaded socket on the stock shafts. It was an investment in assuring me it wouldn't happen again. I think they also sell individual bushings.
http://www.globalwest.net/1967-69_Ca...ngs-Shafts.htm
68 Convertible | stockish 350 | 700r4 | 3rd Gen Power Steering | Dual Electric Fans | MSD Ignition | Island Teal
Old Jun 18th, 10, 07:31 PM
DVINNY's Avatar
DVINNY DVINNY is offline
Dustin
Mine was missing a bolt and washer for 5 years before I started this full suspension / steering setup replacement
kinda glad to hear I'm not alone and the reason above as to why it backs out makes good sense to me
DVINNY's '68 RAGTOP 327
Old Jun 19th, 10, 02:09 PM
zdld17 zdld17 is offline
Don
Control arm movement up/down, will eventually cause washer to turn , usually the cup washer is seated against the control arm bushing sleeve serrations and bushing movement slides around inside cup, Good ole snot grease works well here to eliminate this as well as squeaks.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
