| Team Camaro Tech Current Topic: Del-a-lum bushings are they worth it over poly? | ||
| Brakes, Suspension & Steering Conversion questions, Steering & Handling |
I have a 69 in which I am doing frame off resto. I am going to have the a-arms powder coated so I will need new bushings. Are the Global West bushings and shafts worth the extra $ over just replacing with poly bushings?
| Sponsored Links | ||
Advertisement | ||
Hi i used poly bushes on my upper A arms and to be honest they were rubbish , they were energy suspension ones , there far to soft deform to easy and are not up to the job. I turned some new bushes up at work out of harder nylon bar and they dont deform and my suspension doesnt rattle every time i go over a bump .If you have the money buy the better bushes .
Pete.
life, dont talk to me about life. |
If you want a better performing geometry ![]() As stated above, most of the 'kit' type poly suspension stuff is junk. The durometer of the material is all wrong for most vehicles and the deformation of the bushings allows the suspension to rotate around the bushing vs. maintaining the geometry needed for excellent handling. Might as well use 'Jello' as most of the kit bushings
1968 Convertible Some trucks ![]() Other V8 things - some of which float Other V6 things - none of which float ![]() Oh yeah, and 1 "Straight-Six" ... ![]() If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
I had polys in there. I had done a suspension upgrade a couple of yrs ago. They were better than the originals. But now I am doing a body off resto. So I am going to powder coat my a-arms and subframe. so wanted to hear from those that had maybe used both. John or Peter, have either of you used the rear leaf spring bushings?
I have delrin bushings in my uppers and lowers. I wouldnt go any other way. As far as leaf springs, you can use delrin in both sides, but if you use it in front eye of leaf spring it will be a harsher ride than poly or rubber. Just keep that in mind.
69 SS-350-470hp, TKO-600, DSE Coilover conversion suspension w/Koni shocks, Baer brakes w/hydroboost. 69 project for my wife - SS 396, Glacier blue http://www.camaros.net/forums/showthread.php?t=176706 |
That said, you still need to fix the geometry by adding a tall spindle, or tall ball joint or relocating the upper control arm. Nothing else will fix it (even tubular control arms) and you will feel a huge difference by doing so. Tyler
American Touring Specialties - T56/LS1 install kits |
![]() The wording of my answer doesn't convey the thought I was trying to get across ![]() By "better performing geometry" ... I meant - a constant and not continually changing geometry during travel - as effected by the movement of the bushing through the load cycle of the suspension during a cornering and/or braking event. The 'poly' system will have excess movement, when compared to a solid bushed set-up, and will allow lots of geometry change. I guess I should have said to think of it as a constant geometry vs. a better geometry. Do as suggested, in using the taller spindles or other common mods like the Gulstrand, to get an improved overall geometry for the vehicle ![]() Sorry for miswording the answer ...
I am going to go with the del-a-lum upper and lower bushings. Tyler do I also go with their offset shaft or the standard? And for balljoints do you have a part# (MOOG)?
Rock Auto may have your best price on ball joints. Moogs are $21 upper and $25 lower. AC Delcos are a couple bucks more.
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
#11
Are they the tall ball joints? Part numbers?
#12
No, standard height. Moog does not make one that bolts right in. Talls you have to get from Howe or somewhere like that and I think they run around $80 or so. The G mod is free and the results are similar. I don't have either one but am pleased with how my car handles after doing a complete poly rebuild along with new coils/leafs/shocks/sway and 17" tires.
| Sponsored Links | |
Advertisement | |
