68 camaro 12 bolt rear axle - Team Camaro Tech
What's it worth? & ebay discussions
Old Jul 18th, 10, 06:42 PM
dshook dshook is offline
Default 68 camaro 12 bolt rear axle
What is a 68 camaro 12 bolt axle worth? The axle is complete minus carrier and ring and pinion. It is in very good condition with only minor pitting on the the center section. Thanks
Old Jul 18th, 10, 07:09 PM
mrmuncie's Avatar
mrmuncie mrmuncie is offline
Lee
Default Re: 68 camaro 12 bolt rear axle
Housing and axles(with axles not worn) 700 to 900. Could be more if it's coded for 355 to 410 gears with posi.
Lee (in Louisville, Ky)
Second owner 69 SS Camaro 350 A/C Stick
I specialize in Muncie 4 speeds. Rebuilding tranys for 20 years with over 50 Muncies to select from. If your looking for a certian date code I should be able to help.
Old Jul 18th, 10, 09:39 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
What are the codes on the passenger side axle tube? That would be a big factor on price like Lee said. Post the code when you have time.
Go here for more information.
http://www.camaros.org/drivetrain.shtml#axle
If everything else is good, the price mentioned above is a good starting point. I would say less for a 2.56 or 2.73 ratio. More for a 3.73 or 4.56 ratio.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Jul 20th, 10, 05:23 PM
knightmoose's Avatar
knightmoose knightmoose is offline
good 12 bolt rear ends can go for 2k to 2500 easy where im at, any camaro lover will take 2k at least off of the sale of a 1st generation camaro that doesnt have a 12 bolt rear end in her....
it about helping others
