injstreetrods/ larry - Team Camaro Tech
Old Oct 13th, 00, 01:26 AM
joni joni is offline
Exclamation
Hello Larry!
I am planning converting 69 camaro for LT1 and sixspeed. have you done these swaps ?
If so would you like to help me.Can you point what to look and to avoid any troubles.
? i would prefer aluminium head engine.I am going to get it fron gm sport salvage.
thanks Joni
Old Oct 13th, 00, 06:51 PM
lnjstreetrods lnjstreetrods is offline
Post
Hi Joni,
Yes I have done these engines in many different kinds of cars and trucks.
I don't know if you prefer air cond where you are or not but if you want A.C. the compressor on the Trans Am,Camaro engines will not clear the frame on 1st gen cars.If you don't want A.C.,G.M. makes the pulley/bracket to replace compressor,and use the orig belt.If you prefer A.C. you need the Vette engine that has different brackets and compressor location.
If you are set on the 6 spd trans the clutch set up on the LT1 is hydraulic, and the 1st gen cars have mechanical clutch. If you get the complete set up the clutch master cylinder will need to work off the orignal pedal,some thinking and fabrication will be needed.
Decide if you want to go with auto,or 6 spd trans before you get your eng/trans set up,because the harness is different.
Speaking of harnesses I use the orig G.M. harness,as some of the after market harness are $800.00 or so. The harness looks hard but its not that bad.I pull out the wires needed to do the things like;fuel pump,ele smog pump,lock up converter,ect.
You need some relays also to do the fuel pump and some other stuff.Get them used also off of like Pont 6000 cars.
You need an after market fuel pump I'll get you the part # later,at least 60+ psi.
I use the orig LT1 ex manifolds on the Camaro as they seem to breathe really well.If your engine is 96 or later(I think it's the left side)ex manifold has a ex-large flange where the pipe bolts on. Some people modify the flange to the smaller size,but the 93/95 manifold come the right size.
I am going to sign off for now and think some more,because AT&T has cut me off 3 times now.
Larry
Old Oct 13th, 00, 09:36 PM
Post
Hi Joni,
I saw your post in the other section,and you said something about a 93 model engine.
When all this started people wanted the 93 engines because they didn't have the mass air flow meter,and the install looked cleaner.
My opinion is that the 93 has 4-22 pin connectors on the ECM,where the 94 up engines have 4-32 pin connectors. Yes the later is more complex to hook up but the later engines have sequencial fired injectors. This means that the injector fires the fuel in just when it needs to.
I have read reports saying there is no evidence of H.P. change either way. I have installed both types and I feel that the efficency and responce is better on the later sequencial engines.
As G.M. has done things over the years, like the 700R4 it has gotten better with time and I think the F.I. systems are better. It only stands to reason that the ECM with 40 more pins/wires would have more functions avaliable.
I guess since I have mentioned the 700R4 I will say this, The 4L60E trans which is a electronic/computer operated 700R4 is in my opinion the BEST choise for the trans,plus simpler install.
If you should ever want to install a hotter cam the later engines w/ mass air flow are not affected as much with lower vacuum as the engine w/ M.A.P. only (manifold absolute pressure).
Larry
Old Oct 15th, 00, 06:43 PM
Post
Knock Knock, any one home?
Larry
Old Oct 15th, 00, 09:20 PM
Smile
Thank you Larry for your infomative response!! Iam sorruy but i could not respond you sooner becouse i have email only from my work and we have al lest 8 hours time delay because iam from Finland! i hope you understandYou sure had a lot of information. I am sorry not to specify what im looking for in my first emai,but i want 6 speed,no aircondition and i think i can modify the hudraulic clutch to work,if its
not too difficult.
Yes you were right about the massair flow sensor thing,it looks ugly to me,but i have heard at it could be modified to work without it? converting to speed density? Is it raelly possible to make it work with gm computer? can i leave all emission staff away(like airpump/egr)?
thank you larry again,hope to hear from you soon!
Old Oct 16th, 00, 07:20 PM
Post
Hey Joni,
Sorry I didn't mean to sound impatient, I was just messing around.
I took apart an eariler model ( 88 ) V6 -5 SPD car last week, and the master cylinder was mounted just under the brake booster at an angle so to miss the booster. It had a remote resovior for the brake fluid. The best thing to do is try to find a LT1 6 SPD car with all the parts still in place, and do some measuring so you can cut the hole in your fire wall in the right place.
Yes the G.M. computer can be made to function perfectly in the conversion. We will need to deal with the V.A.T.S. (vehicle,auto,thief,system). Some people send the ECM some where and get this burned out, but I prefer to make it function with hidden toggle switch. I have paid as much as $300.00 to get ECM reprogrammed,and VATS burned out.To make the VATS work I buy a box that was costing me $160.00,but the guy has had a company start building these and the last bunch I bought was $49.95 each and they seem to be working fine.So by using this box and a hidden switch the car will only start-die,start-die,and not keep running until the switch is turned on. Without the VATS box the engine will start-die until the box is installed.
All the emission stuff can be used,or deleted I don't see where any performance is lost in keeping it working though.
I am now in the process of researching the speed dinsity thing,there is a new link for these cars and I just havent had time to follow through on this, and check it out.
Go ahead and research the cost of engine,
trans, and let me know if this is for sure possible and I will try to continue with enough info to get you through this.
Larry
Old Oct 16th, 00, 09:17 PM
Post
Thanks again Larry!! You seem to have all the information at doing this ! it makes me feel sure to start doing it!!!
OK ,i start looking what kind of options do ihave .i have to bay the engine/trans combo in certain salvage yard because my friend has a business near it in florida,that way he can check it out and take it for me!
i was wondering can you mail me direct,so i could get your personal email and liked to dicuss more and how i can make up all your help! my email is joni.kiurunen@kesko.fi
thanks Larry again!
Old Oct 23rd, 00, 06:17 AM
derekf derekf is offline
Tech Team
Post
Whee!
Sat down and had a long talk with the wife this weekend, and she (in theory) has agreed to let me get an LT-1/Tremec for my 67.
This raises its own group of questions though.. I see that the AC compressor is in the wrong place - is there a way to move it, or does this just end up being a non-AC car?
Also, when I go to find my motor/tranny, what other parts do I need? (pretty sure computer, wiring, fuel pump, but I'm sure there's other stuff I'm not thinking of). Anyone have a list? (Larry, you might need a website if you keep getting asked the same questions over and over - lnjstreetrods.com would appear to be open
Thanks, y'all.
camaro@derekf.com
67 Camaro Basket Case
69 El Camino SS396 (Daily Driver)
Old Oct 24th, 00, 04:54 PM
Tech Team
Post
Ping!
(sorry, but this got buried pretty quick)
camaro@derekf.com
Old Oct 25th, 00, 10:29 PM
Post
Derekf,
My heart bleeds for you I am in Ft worth just a hop and a skip away.
Well here goes you guys, I want to use this thread to help others, and I am like Joe, and Mike, or who ever I just like cars and no I don't wear pennies in my penny loafers. Now if you haven't heard that commercial this don't make any sense.
Yes I am in the business of auto repair, up to now I have tried not to advertise in any way, just help. My shop is geared toward high performance, conversions (V8 Jaguar and more)street rods, and hipo automatic tran's.
I am still not here to advertise, but I do want some input from all who are interested in the LT1,s in any way.
I have installed at least 10 of these engines, and I never use after market harneses. I modify the factory harness, to work to it's full potential, run in closed loop, with the OBDII data link to scann the system if problems need checked.
The after market harneses are from, $500.00 to $800.00. If I take a car in after engine instillation, to only finish the wiring, it normaly cost from $500.00 up to complete the harness, make a new section of harness for all the relays, such as fan/or fans, fuel pump, smog pump, lock up tq conv, main ign system, and so on.
So here is what I want to here from on you on. What if I develop a do-it-yourself book, that has part #'s, where to and how to. What parts you can buy at the wrecking yard to save money, and a web site to discuss problems, or order stuff from.
Let me know if you would be interested in such a book and if so what should it sell for.
I only want to do this to get my 1950 LT1 Studebaker pickup off the back burner, we ALL know how hard it is sometimes to afford our projects.
Larry
Old Oct 26th, 00, 04:16 AM
Tech Team
Post
Hi Larry,
Yeah, I knew you were in Ft Worth (we met before the last Ballpark swapmeet if you remember)
I personally would pay a premium for a book like that - although these days I try not to buy books that are over 30 dollars or so.
Website would also rock, have not found any websites that seem to really cover this kind of stuff. If you need help setting that up let me know; I ain't the best at it, but I'm free so it evens out.
camaro@derekf.com
69 El Camino SS396 - now with 500,000 miles!(Daily Driver)
Old Oct 26th, 00, 04:19 AM
Tech Team
Post
Also might like to see in such a book a section on the modifications that can/should be made to an LT1 before installing - cam changes, etc.
This might be outside the scope of the book though.
Old Oct 27th, 00, 01:23 AM
Post
Derkf,
I thought that was you but wasn't sure thanks for the input, I'll just wait and see if anyone else has an opinion.
Larry
Old Oct 27th, 00, 03:45 PM
Teetoe_Jones Teetoe_Jones is offline
Post
Well lets see if i can shed a different light on the subject.
So you want an LT1 without A/C in a 69 with a T56 six speed eh? Well here i go.
LT-1/T56 swap ideas:
I suggest finding a 67-69 Camaro/Firebird, or 68-72 Nova to perform the swap on, since I know that it will work on these chassis/bodies.
The next step is locating a 94 or newer LT1/T56 combo from a donor car. Camaro/Firebird versions will work, as well as Corvette, and even Impala’s. The only drawback to the impala motor is that it is not only a 2 bolt main, but is also iron headed, as opposed the the Camaro/Vette version with aluminum heads. The corvette version is my personal choice, both because of the 4-bolt main, and the location of the accessories. The Camaro/Firebird LT1 has the accessories mounted low (except the alternator) on the passenger side, and the Vette version has the accessories on the driver’s side, high up.
The problems for mounting the engine are as follows:
Camaro/Firebird LT-1’s will require an A/C delete pulley to clear the frame on these cars. ( GM part number 10115875 ) The compressor is mounted too low to use with out notching the frame rails. The alternative is the Vette, which will bolt in with no problems or modifications. I don’t recommend using the factory exhaust manifolds, but instead buy a set of good headers. I chose Hooker super comp headers with 1-5/8” primaries to a 3” collector. From there I welded up a collector-to-collector spacer that had a bung for the o2 sensor, so I wouldn’t mess up the expensive headers. (picture available on request)
As far a wiring up the motor I also don’t recommend trying to use the factory harness, but instead purchasing a high quality aftermarket harness from one of several companies. I used TPIS, but can also recommend, street and performance, Painless wiring, and Accel DFI. The only computer modification I had done was a PASS key disable. I would recommend getting the LT1 edit program if you retain the factory computer (unless you go with Accel’s DFI)
As for the T56, we know it came with LT1’s from the factory, and the set-up works well, so why mess with it. The starter clears the headers; the Flywheel and clutch work well, and there is no need for expensive custom bellhousings or exotic flywheels. What I did was retain all the factory settings, and purchased a bracket from an outside source. This bracket mounts on the 4 studs behind the brake booster, or master if you don’t run vacuum assisted brakes. It is angled at a 21-degree slope to match the firewall on the 93-97 Camaro/Firebird. The hydraulic clutch actuator mounts to this bracket with 2 bolts, and a pushrod goes through the stock clutch hole in the firewall. The pushrod is then mounted to the clutch pedal with an offset spacer that allows for full travel of the pushrod’s stroke.
NOTE: This is the only place where the Camaro T56 setup shines over the Corvette’s. The 92-96 vette used the ZF 6 speed, which is totally different, and I have no idea how to set that up in an older car.
The other end of the actuator goes in the T56 bellhousing and pulls the clutch off. Fairly simple, and the only welding is on the pedal spacer.
After the motor is in the car with headers, and accessories, install the flywheel then the clutch and flexplate. Then hoist the tranny into position and bolt the bellhousing to the block. Here is where most people get frustrated. There is no one that offers a pre built crossmember for this application. I AM WORKING ON ONE CURRENTLY. If you fab one up, you are doing well. The driveshaft will need to be shortened; I’ll get measurements soon. Then hook up the clutch actuator and engine wiring, and have fun. Oh yes, I forgot about the shifter hole. It will need to be moved 2” back for those of you with manuals, and cut from the location if you have an auto.
Any other questions can be directed to Tyler @ teetoe_jones@hotmail.com
So, i personally recommend buying the aftermarket harness, mine was 475 with all the relays and no exra wires. The pass key was also disabled by TPIS for 150 bucks. Pretty damn reasonable. If you guys are that interested, i'll complie a list of the things and p.n. used on my car, as well as sources for all of it. Let me know.
1968 RS/SS Camaro w/ 94 vette LT-1 and T56 six speed, Cal-Tracs, Baer 12" crossdrilled brakes 17" rims, ect....
<A HREF="http://home.earthlink.net/~speedracer68/tyler.htm" TARGET=_blank>
My 68 with LT1 and T56</A>
Old Oct 28th, 00, 06:58 AM
Post
Hey Tyler,
I just want to say how much I appreciate your input and the knowledge of the 1st gen/LT1 marriage, this is just a killer way to have the best of both worlds. (HP/Mileage) You have shared things here that I just haven't had time to address and that is good. I also like your car and the installiation looks really good.
Has Hooker started making Super Comps for the 1st gen car with head flange plates to fit the LT1 "D" shaped ex port? If so what is that part #.
I guess the old saying, different strokes for different folks would seem propper here. I am not trying to be smart or opposed to your approch in how to go about this instilation, but I do have a different idea to share.
As for myself, and I think many of you will agree, if I can spend more time and less out of pocket money to do a project I must choose to spent the time.
The thing also here is not just the money issue but for the love of doing a car our self, that is what we want it to be and the pure pleasure of the since of accomplishment, and the pleasure of strutting down the street in something that many others don't have. But here is the problem, I don't have the money to go out and buy,LT1 edit programs, Accel DRI, or hi dollar after market harnesses.
So here is my idea, when you buy most any LT1 it comes with the computer, and the GM harness.Why not spend some time on the factory harness, pull out the wires necessary to make this harness work, go to the wrecking yard and buy some used relays that no one want any more any way (cheap)and spend the money saved here on something else.
There is also now an anti thieft box (vat) for about 1/3 the cost of reprogram stuff, and it only has 3 wires to hook up and 2 of those are, pos/neg. You can also use a hidden switch on any of the 3 wires and make the VAT work for your protection.
I will close for now in saying please don't misunderstand I am not being smart in any way at all, I just know I have a family, and bill's and other things to consider, and if I can find a way to save money on my projects I must or let them wait longer to get done, and I want to drive it rite now!!! don't you.
Your's truly Andy Rooney, I mean Larry
