Fuel inlet thread size for a q-jet? - Team Camaro Tech
Thread Tools Display Modes
Old Aug 6th, 10, 08:16 AM
brewcity brewcity is offline
Default Fuel inlet thread size for a q-jet?
Hey guys,
Does anyone know the size of the fuel inlet thread size on a 4bbl Q-jet?
I need a flared connector to the fuel line, but cant seem to find one that fits into the fuel inlet. I have tried 3/8, 1/4, 3/4, and anything else I could find to no avail. Is the fuel inlet on a q-jet a standard size? Someone mentioned to me that its a 5/8"-18. Is this correct?
If someone could help me, that would be great! Thanks a lot!
Old Aug 6th, 10, 08:40 AM
Everett#2390's Avatar
<Jake-68's rule
Default Re: Fuel inlet thread size for a q-jet?
For A Q-jet, it should be the same flare nut as a 3/8" diameter tubing just like the tubing lines hanging up in the parts stores.
9/16" wrench across the flats of the nut.
Old Aug 6th, 10, 09:24 AM
I thought so too...but a 3/8" male fitting didnt fit.
I am looking for one of these I think:
http://www.jegs.com/i/Earl%26%23039%...91947/10002/-1
but just need to know the right size.
Thanks a lot!
Old Aug 6th, 10, 09:56 AM
novaderrik novaderrik is offline
you use a 5/8" wrench on it- i think the actual thread size is 5/8", too.
just call Jeg's and ask them which fitting to use- i'm sure they get that question a lot.
you don't plan sincerity.
you have to make it up on the spot.
wanna hear about 20 years ago when i was too smart to know any better?
Old Aug 6th, 10, 10:02 AM
<Jake-68's rule
Carb info:
http://www.carburetor.ca/carbs/tech/...jet-index.html
'67-71 has 7/8"-20 threads; '72-'79 changed to 1"-20 threads for the fuel inlet nut on the carb used to connect the fuel line and hold in the inlet fuel filter.
Yes, could be a 5/8 inch wrench, been a while.
Old Aug 6th, 10, 10:22 AM
Vintage 68's Avatar
John
Wink Re: Fuel inlet thread size for a q-jet?
The common inlet thread sizes for the carb body are 7/8"X20(sae) or 1"X20(sae) - although there were some 5/8"X20 also for some BOP models. (note: these are an 'SAE" thread pitch, not typical NPT or other common ones)
The most common stock fuel line flare sizes are 5/16" or 3/8".
Try getting a couple flare fitting nuts from an auto supply store and seeing what fits.
Summit and others have a good selection of them, even Edelbrock sells them ...
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Aug 6th, 10, 10:40 AM
Great! Thanks so much to everyone!
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Fuel inlet thread size for a q-jet?
Location
Location
First Name
Human Verification
