traction bars help ID - Team Camaro Tech
Thread Tools Display Modes
Old Aug 8th, 10, 11:57 AM
msicks msicks is offline
Default traction bars help ID
Anyone know who makes these and how they work?
thanks
Old Aug 9th, 10, 04:03 PM
Default Re: traction bars help ID
I found some info on these there ansen ground grabbers
Old Aug 9th, 10, 09:46 PM
davidpozzi davidpozzi is offline
David Pozzi
Yes, Ansen made them. For strip use, you are supposed to put big bolts in the rear holes to lock them. If you do, your spring perches will eventually rip off, mine did on my 67 which as in the photo, don't use U bolts. First you see an oil leak where the perch is welded on, then it rips off.
Those are heavy bars!!!
Check my web page for First Gen Camaro suspension info: http://www.pozziracing.com
67 RS 327 original owner. 1965 Lola T-70
Old Aug 10th, 10, 04:27 AM
Everett#2390's Avatar
<Jake-68's rule
Haven't seen those in ages! Yes, very heavy!
As David suggests, they do rip off the spring perch. As a deterent, kindda, weld in plates from the top of the spring perch to the axle tube to triangulate the perch.
Old Aug 10th, 10, 06:36 PM
If you run them on the street without the bolts in the rear holes are they alright. Can you add U bolt to these? What color were they originally?
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: traction bars help ID
Location
Location
First Name
Human Verification
