68 Vert stored 21 years - Team Camaro Tech
Build Projects follow along start to finish
Old Aug 9th, 10, 11:39 AM
kettbo kettbo is offline
George
Default 68 Vert stored 21 years
No stranger to old cars, drag racing or turning wrenches. Am very active on Team Chevelle. I have been looking for a nice 68 for some time. All the finished cars I've seen are 'not me' in color, finish, options, modifications, ideas of what right looks like....and all are way over priced! 'Project' cars were much abused, apart, money pits, etc. I found this 'TWEENER the other week. Seller listed it as 68 SS Convertible in the ad title yet went on to say 327/automatic.... I sent a pretty blunt note (no number listed or i would have called) and to my surprise, I got a call from the seller a few days later, "Hey smart guy...this is LLLLLLL with the Camaro. Seems you know a lot about these. I called you first..... ......" She got the car in 1980 after HS, her baby. She parked it 21 years ago in her garage.
Needless to say, I got there quick as we could coordinate a date and time. She had already washed most of the "Barn Find" off the car. A deal was made...she wanted a good owner, I guess I qualified. I dragged it home FRI a week ago. Needs at least qtr skins, driver side toe pan and dvr side rear passenger foot metal.
gotta love the paint over bondo
Has the 'born-with' 327/210 "ME" block, though someone swapped on 1964 Power Pack heads. I have not checked the Glide's ID yet. Have found the remains of two mice so far in the front of the car
Interior shot. Has a working Power Top
Diff is 10-bolt with 2.73 (can't find the code but the count the revolutions method used to determine ratio) and posi, posi sticker in the trunk. J Code Rallye Green, 2 for black soft top, with 712 black std interior. Console. Bumperguards on NICE bumpers. Rear mount antenna.
Low quality repaint. POS non-correct 1969-type hockey stick stripe
I traded away the rusty APPLIANCE wheels and tires hard enough to turn a sharp-edged knife for some aftermarket 14" rally wheels and somewhat newer roller tires until something definite is resolved in the wheel and tire department. I am more of a gearhead than a 'numbers' guy. I spent a few hours on it SAT a week ago. Got it running, will spare you the details unless you really want to know. As it was tail-in the garage, I turned it around SUN to address the brakes, or lack there of. First time under its own power in 21 years. Normal 4-wheel drum brakes. Rears were near mint, fronts well done, master cyl shot. I sell auto parts so new MC, 4 wheel cyls, 3 new soft lines, new front drums and shoes. Front stuff is already on this SAT and SUN evenings. After this, complete lube and diff fluid change.
I plan a road test to figure out what's what before deciding what way to go with this. Upon start-up, observed a steady drip from the rear main. Nice crusty residue on the pan shoe this problem existed before the engine was parked. It is not getting any better. Some regular well-used 327 engine sounds lead me to think a basic refreshening is in order. Moderation in my underhood activities will observed. This will be a cruiser. Looking at 'Day 2' looks here. Probable upgrade to 327/4 bbl status. The single exhaust blew a rats nest out as well as lots of metal flakes onto the garage floor. She will get a dual exhaust. We'll see how I like the Glide and 2.73 gears.....she'll be Emily Post polite, everybody else will go first! I want some road time before the rains come in only a few short weeks. Do some major work on the beast this winter.
I like the J Code paint. Wifey is trying to talk me into a white deluxe interior and white top with more chrome and the white later type stripe. I agree, would be a stunner. Probably put some nice tires on my 15x7 Monte Rallys, 215/70s or there about.Maybe other wheels. IF this was a high option car, would dare not change a thing....but as a mostly base vert....thinking tasteful upgrades would add to the looks and value....comments appreciated!
George Kettler
o 70 Elky 454/3000 stall/3.42 gears
1.632 60ft, 11.726 ET, 113.49mph
o 68 Vette 427/M-20/3.36 mine 22 years this Fall
o 68 Camaro Rallye Green Vert 327/210 http://www.camaros.net/forums/showth...183654&page=52
Old Aug 9th, 10, 11:45 AM
George
Default Re: 68 Vert stored 21 years
Here is the turn-around vid wifey shot SUN a week ago
George Kettler
Old Aug 9th, 10, 11:52 AM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Nice project George! I suspect you wont like the PG and 2.73 gears
Old Aug 9th, 10, 12:10 PM
George
Kevin, my street Elky runs well into the 11s.....so you hit it dead-on. But this will be a cruiser.... Wifey says all my cars get big engines and are ruined. She wants to go for drives, trips and such...the Vert will be perfect IF I keep it sane.... She's pretty tiny so the Camaro is the perfect size. I am thinking the PG may go to the corner of the garage under the bench and yield to a TH350. Or I could 2004R and change the diff ratio or simply bolt in a 8.5" 10-bolt with say 3.55 or 3.73. The OD would knock the effective cruise gearing to 2.40---2.50. This would mean I'd have to be very careful on the cam selection, something that likes good gearing 2.74 1st gear in a 2004R x 3.73 diff in a light car makes for spirited performance...but good response for no surging at low cruise rpm.
Shot of the trunk, looks nice! Surprise, good metal! Cocktail shakers are present too
under the lid
George Kettler
Old Aug 9th, 10, 12:11 PM
Melrose RS Melrose RS is online now
Tom
Nice find George!
New brakes, check the fluids and hit the road to see how it goes.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
(And an 8 year old riding shotgun. )
the Melrose rs - L30 327/275hp
Old Aug 9th, 10, 01:05 PM
RSSSfanatic RSSSfanatic is offline
Tom
Love that Rally Green! I agree that white top, interior and stripe would really set it off, but the black does not look bad either. To save some money, it probably wouldn't look bad with just a white stripe and top, and leave the interior black. I actually kind of like the old Appliance wheels on it - gives it the old school, day three look to it. A Q-jet with a mild cam, along with an OD tranny and some decent gears will give it some snap, and if you stay out of the secondaries you can knock down some pretty good highway MPG. BTW, I have a 67 with 245-60-15 radials on 15x7 rallies, and they fit pretty good and really fill in the wells nicely.
1967 RS/SS 350 Conv - triple black, 4sp, tach & gauges
1969 VN-built RS/SS 396 Conv - Garnet Red/Black, 4-sp, tach & gauges
Old Aug 9th, 10, 03:10 PM
70ChevelleLS5 70ChevelleLS5 is offline
Team Member
Rob
ive got a nice 68 RS Ill trade ya nice find
Old Aug 9th, 10, 03:32 PM
George
The tires were 195s....looked bigger with the 14 x 6 or 14 x 7 with all of 2.5" BS on the wheels....mega deep dish...
Keep the ideas coming!
George Kettler
Old Aug 9th, 10, 05:56 PM
Everett#2390's Avatar
<Jake 68's Rule
Nice find and the correct year.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Aug 9th, 10, 11:55 PM
George
Wow, 174 view and only a handful of responses/comments. Say something, offer advice or don't even look. Damn lurkers!
Get on the freight train for a very good time as I blog you to tears on this project.
We'll get her running as a "MUTT" for now...enjoy the ride, then turn her into a princess or something sweet over the winter.
New shocks and swaybar recommendation please! I sell Monroe at work, anybody got input on them?
Wheel and tire ideas are always accepted...Rallys or ??? Pics always work!
George Kettler
Old Aug 10th, 10, 12:05 AM
BPOS BPOS is offline
Al
Nice convertible project, George. Bring it down to Vantucky some day and we can swap lies.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Aug 10th, 10, 03:51 AM
<Jake 68's Rule
Why not keep it stock configuration and use your Monroe shocks, an aftermarket swaybar, if one is not installed, set of rally wheels or Torque Thrust-D's or solid Centerlines? 225/70-15's?
Later on, fix the qtr panel, repaint to color of your choice, keep the black interior as black goes with anything just like blue jeans, maybe replace the PG with a THM350, keep the rear gear as is, you'll not gonna drag it and you ain't gonna highway travel with it, so why go for a TH200-R4?
It's a daily driver, grocery getter, and a cruiser to turn heads. If the Honda boys come up and try to intimidate ya, just smile and wave back. It ain't worth it to risk it with Johnny Law. However, I do find it hard not to and grit my teeth........
Old Aug 10th, 10, 06:36 AM
captcanuck68 captcanuck68 is offline
Ted
Nice find, great year, a step up on the revolution car pole... guess they're still out there.
Dep upon how deep the pockets are... some good suggestions to date...350 tranny in, quarters, maybe a disc exchange on the fronts...good paint...top looks good?
I'd be tempted to stay with the just front recover...and nothing wrong with the high rear(still can chirp the tires,,,and don't forget to check the code, eh?)...great for cruizin', and with the price of gas today?
Thanks for sharing.
capt
Old Aug 10th, 10, 08:53 AM
George
The Dvr qtr damage is an eyesore.... Looks like the wheel arch had some rust damage and a shop long ago did the Bondo and spray repair. Only looks like surface rust on the wheel house...an sure I'll find more damage than I expect, but I want to remain optimistic for the time being. Passenger QP is less damaged but probably more flaws than apparent.
225/70/15s...ok.... the Vert now wears Rallys in 14x6 with some blackwalls. Will shoot some pics next time the wheels are on. These really need some better chrome rings. I do have Monte 15x7
The front sway bar is pencil-thin. I had a 78 Z-28 long ago..good handling rig until I had the 85 Vette with z-51 package and the 315/ZR40/16s...OMG, I discovered handling!
I am not a fan of the "everybody" Cowl Hood, spoiler, and SS Stripes. Played-out like a bad record. No offense intended if you have gone this route, just not me.
I do believe the GLIDE will be retired when the engine comes out for rear main seal repairs. Also perform an eval of the engine. Got the feelers out for some period-correct Camel Hump heads, will sell the Power Packs. The th350 favorable 1st gear will really help the 2.73s. This is my initial thought. I do have a pal with a free 72 8.5" 10-bolt Nova diff....maybe gather parts and such and do all this down the road.
ref Johnny Law...
been hanging out with PDQ67? heehee?
I make it a point to my young customers and the kids from work to take their racing and such to the Track. We are blessed with Bremerton AND Pacific tracks, both less than an hour drive. The Camaro will be a cruiser...if I feel the need to intimidate, the pale yellow 68 Vette packs a healthy 427 and 4-spd in roughly 3400# package and the street Elky just sounds bad-*** with 11.7 time slips as back up
Thanks for sharing.
capt
I have two other cars with black interior, the 68 Vette and the 70 Elky. While black interior is a good thing, PLAIN JANE, PJ, in a VERT does not make sense...at least to me. Seems like a wasted effort. I did tell wifey, "Carpet kit, 2 door panels, arm rests, and a used dvr seat cover and the interior would be good to go"...think she gagged! With the gal interested in a George project for a change....financial backing not financial obstruction...thinking best to go where the cash takes me.
The top is in very good shape. Needs some fixing near the passenger rear window, have not investigated. One plan involves upgrade of the interior to white deluxe and keeping the black top for a few years. This plan has merit cost-wise as well as practicality/upkeep of a white top. The car will be garage kept and fair weather though I must say with W WA weather, spring and fall outings I could see some unscheduled showers. White nose stripe to go with the white interior. The black top goes with black carpet found with white interiors and tire colors. There is the decided 'old car smell' present. If the removal of the last of the carpets, clean-up, etc does not rid the vehicle of the smell, if the top still smells...it goes.
George Kettler
Old Aug 10th, 10, 10:49 AM
markspark's Avatar
markspark markspark is offline
Mark
I bought a similar car about 10 years ago, I drove it rust and all for about 5 years. I thought it was going to be an easy restore so to make a long story short Ive replaced the full floor and trunkpan, inner and out wheelhouses, tail panel, quarter panels, door, fenders, ect. Once you get into restoring the vehicle you find rust everywhere. Not only that but when your going to have 4 - 6 years into a restore you dont want any rust anywhere! The only metal I was able to save was the trunk lid and hood!
Good luck, I know I have learned alot and continue to learn from the site.
