YW code rally wheels - Team Camaro Tech
Wheels & Tires What fits what?
Thread Tools Display Modes
Old Aug 13th, 10, 09:46 AM
jlb307 jlb307 is offline
Tech Team
Jeff
Default YW code rally wheels
Still quite the newbie, so I need some help from those in the know.
Got my eye on a set of 14x6 rally wheels coded YW for my '67 when I get her back from the body shop next week.
I was thinking of going with some BFG Radial T/A 235/60/14 all the way around, considering the 245's too.
Stock suspension, ride height, rear end, and drum brakes (all for now until I can convince the wifey to let me upgrade) and I was wondering if this wheel and tire combo will fit and not lead to any rubbing problems.
Any help is greatly appreciated!
Old Aug 13th, 10, 09:52 AM
Melrose RS Melrose RS is offline
Tom
Default Re: YW code rally wheels
The 14x6 rim won't fit the 235/60/15 tires.
235/60/15 fit well on 15x7 ralleys. That's what I run with 15x8 on the rear.
245/60/15 would work well on 15x8 ralleys on the rear.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
the Melrose rs - L30 327/275hp
Old Aug 13th, 10, 12:22 PM
Tech Team
Jeff
I meant to put 14, so I changed it to the right tire size in the original post.
So do you think they'll fit now?
Old Aug 13th, 10, 01:13 PM
Tom
235 60 14 should be the same width as 235 60 15. So if the backspacing on the YW is the same as 15x7 ralleys (4.25" IIRC) then they should work but you may have scuffing against the frame on tight turns. Mine does.
Old Aug 13th, 10, 04:31 PM
Tech Team
Jeff
the YW have a 4 3/8" backspacing, so I guess I'll still get some rub.
Old Aug 13th, 10, 07:09 PM
67 Plum's Avatar
67 Plum 67 Plum is offline
Chad
A 235-60 is to wide for a 6" wheel.A 205/70/14 would fit better.
Old Aug 14th, 10, 08:27 AM
Tech Team
Jeff
Weird, I was actually told that up to a 245 would fit on a 6" wheel. Anyway, I forgot to mention that I have drum brakes all around.
Still any idea if 4 3/8" would cause rubbing with a 225 or 235?
Old Aug 14th, 10, 09:51 AM
Jonesy's Avatar
Jonesy Jonesy is offline
Mike
YW coded wheels are 15x7 ralleys
Team Camaro Gold Member #14
1967 Camaro RS/z28 - one of 602 made - SOLD
1969 Camaro RS/SS L48 4 speed
1974 Camaro LT-Z/28 4 speed 33K orig miles
1979 Camaro Z/28 36K orig miles
1984 Camaro z/28 LG4 auto
Old Aug 14th, 10, 11:11 AM
Tech Team
Jeff
According to the guy selling them, they're 14x6. Listed as 14x6 everywhere else I've researched too, for example:
http://www.jalopyjournal.com/forum/s...d.php?t=116373
Old Aug 14th, 10, 11:37 AM
Jonesy's Avatar
Mike
Whoops, I was thinking FW coded wheels, sorry for the mistake.
  #11
Old Aug 14th, 10, 03:39 PM
67 Plum's Avatar
Chad
BFG says 7"to8.5" wheel for a 245-60.
http://www.bfgoodrichtires.com/tire-...dial-t-a-tires click on specs at the bottom of the page.
You can put them on a 6" wheel but they will not be flat acroos the tread and wear in the middle.And yes a 245-60 will rub on the front.
  #12
Old Aug 14th, 10, 05:16 PM
Tech Team
Jeff
Thanks for the link, good stuff to know. Helps me make my decision easier.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Wheels & Tires      Current Topic: YW code rally wheels
Location
Location
First Name
Human Verification
