Need new caliper seals, what size is the bore?? - Team Camaro Tech
Old Aug 23rd, 10, 06:03 PM
operation rob operation rob is offline
Team Member
Rob
Default Need new caliper seals, what size is the bore??
This is for my rear brake calipers. The piston is 2.5" diameter. The OD of where the seal is seated is 2-7/8" - 2-15/16" so which one do I get??
http://www.summitracing.com/parts/DHB-D35494/ (says will fit a 69 camaro with drum brakes??)
http://www.summitracing.com/parts/DHB-D35885/
any help/suggestions??
Old Aug 24th, 10, 11:39 AM
BPOS BPOS is offline
Al
Default Re: Need new caliper seals, what size is the bore??
What kind of rear discs do you have?
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Aug 24th, 10, 01:41 PM
Steptoe Steptoe is online now
Steps
Would it not be quicker to ask summit direct, or just order both...couple bucks not going to brake the bank.
Old Aug 24th, 10, 03:19 PM
Team Member
Rob
http://instantrimshot.com/
problems solved, thanks guys.
