original spare tire for 1969? - Team Camaro Tech
Restoration Corner Where originality comes first
Old Aug 25th, 10, 06:23 PM
butternutx11 butternutx11 is offline
Tech Team
Shawn
Default original spare tire for 1969?
Anyone know what brand/size GM used for spare tires in 69? I just picked up the original spare that was from my low mileage 1969 camarocar. The previous owner found it and gave it to me. The car was owned by the same person from 69 to 2008. The rally rim is date stamped the exact same as my other four wheels on the car, 9-27-9 XG. However, Im trying to figure out if the tire is the original or not. It is a Firestone, 195/75 R14 I think. It has some yellow markings on the tread where it would touch the ground. It looks pretty old....Thanks for the help.
Shawn
1969' x11, late production butternut yellow
Old Aug 25th, 10, 06:46 PM
Unreal Unreal is offline
Gary
Default Re: original spare tire for 1969?
Post the date code close to the bead. I don'y know how to decode it, but someone here will be able to help. Won't prove it's the original spare, but will at least give you its vintage.
Old Aug 25th, 10, 06:51 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
I am not sure what the spare size would be.
Tires on the car for an X11 would normally be E78x14 (standard) or F70x14 (optional).
Not sure when the tire size changeover to the new way of doing numbers took place.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Aug 26th, 10, 03:58 AM
KevinW's Avatar
KevinW KevinW is offline
Kevin
A metric sized tire was not original to a 69 Camaro, period. the tire was replaced at some point.
