Easy rear seat removal and install - Team Camaro Tech
Old Sep 5th, 10, 03:44 PM
PBayer PBayer is offline
Paul
Default Easy rear seat removal and install
My seat was crazy hard to remove and impossible to install. Heres my answer to the problem.
I used a piece of steel placed onto the two bolts of the front seat to provide a base for the bottle jack. Used bottle jack from my dodge truck. Used a 3/8" x 6" bolt with a notch ground in one end. Lay jack against steel and place bolt on end of jack w/notch on frame under rear seat. Used cordless drill to crank jack. cranked the frame back to the seat hook, pushed down and lowered jack. Instantly hooked. Took 1 minute. Hope this helps.
Click image for larger version
Name:	rear seat inst 1.jpg
ID:	17616   Click image for larger version
Name:	r s 2.jpg
1969 Camaro 468ci, 700R4 (Probuilt kit), s60 rear w/3.73.
Old Sep 5th, 10, 05:33 PM
Steptoe Steptoe is offline
Steps
Default Re: Easy rear seat removal and install
Yep , unless one doesnt know what the clips look like, it can be a bitch of a job.
Trick is pull the rear seats Before the fronts.
This then gives one something to lean against, push in at the bottom, a little down, then it flicks up...then the other side.
Then remove the back of the seat.
Once one has done this and sees how it catches in , in the future is not a hard job.
Old Sep 5th, 10, 08:44 PM
rogerh rogerh is online now
Paul its a great tip. THANKS
Roger
1967 Camaro SS/RS 350/295HP Coupe. First and only owner.
