Aluminum Intake Manifold Torque. Really? - Team Camaro Tech
Old Sep 15th, 10, 05:17 AM
DarrenX33 DarrenX33 is offline
Default Aluminum Intake Manifold Torque. Really?
On a BBC aluminum intake manifold. Has anyone ever heard of torquing all bolts to 30 with the exception of the 4 bolts above the ports (2 on each side) which get about 12-15?
-Darren
Old Sep 15th, 10, 07:34 AM
Melrose RS Melrose RS is offline
Tom
Default Re: Aluminum Intake Manifold Torque. Really?
If that's true it would surprise me. I'd guess 15 -20 is enough for any of them.
But I don't build big blocks so as I said, just a guess.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
(And an 8 year old riding shotgun. )
the Melrose rs - L30 327/275hp
Old Sep 15th, 10, 10:24 AM
IRON MAN IRON MAN is offline
Terry
Never heard of it. 30 ft lbs tq on all of them.
Why? Have you heard of it? I,ve owned a 66 Chevelle SS396, 67 Chevelle SS396, 71 Vette 454, 71 Chevy stepside 402. News to me. Have heard of if you have an aluminum manifold, the bolts must have hardnened-steel washers under them or the bolt heads will dig into the manifold.
Just read Weiands BBC Intake manifold instructions which state, "The bosses at bolt hole positions 13,14,15, 16 are not well supported and should be tightened gently by hand with a 6" box end wrench only after bolts 1-12 have been torqued to 25 ft lbs." Weiand says to use three rounds of torquing bolts 1-12, in steps of 10 ft lbs, 18 ft lbs, and 25 ft lbs. Guess I am lucky not to ever have broken an ear off. Will change my torque settings in the future.
Old Sep 15th, 10, 11:38 AM
Instructions that came from my engine builder. Motor is a stock L78. Seemed odd to me as I have never heard of it before then. Thought I would ask around for some opinions.
-Darren
Old Sep 15th, 10, 11:44 AM
I understand now. You cannot torque those bolts because of a lack of gasket support in that area. If over tightened it can cause damage to the manifold.
-Darren
Old Sep 15th, 10, 11:51 AM
kettbo kettbo is offline
George
BINGO. The ears have been known to crack or break off. The aftermarket intakes are tougher in those areas. Use commons sense....if it looks wrong, it probably is wrong.
George Kettler
o 70 Elky 454/3000 stall/3.42 gears
1.632 60ft, 11.726 ET, 113.49mph
o 68 Vette 427/M-20/3.36 mine 22 years this Fall
o 68 Camaro Rallye Green Vert 327/210 http://www.camaros.net/forums/showth...183654&page=52
Old Sep 15th, 10, 12:03 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
I have never used a torque wrench on aluminum intake bolts. Always went with the old timer rule of "get 'em tight - but not too tight". Then check them again after the engine has gone through a couple of heat cycles.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Sep 15th, 10, 12:11 PM
knuggles68RS/SS knuggles68RS/SS is offline
Team Member
Mike
Correct...The instructions I got with my Edelbrock RPM performer stated do not torque those 4 bolts due to the lack of gasket support...I believe it said to just hand tighten those bolts.
