What is the difference between 12 bolt car and truck carrier? - Team Camaro Tech
Thread Tools Display Modes
Old Sep 17th, 10, 08:38 AM
Jim H Jim H is offline
Tech Team
Default What is the difference between 12 bolt car and truck carrier?
Old Sep 17th, 10, 08:50 AM
67econobox 67econobox is offline
Joe
Default Re: What is the difference between 12 bolt car and truck carrier?
Truck carriers have a smaller pinion shaft diameter.
67 RS Convertible - Twin Turbo 565, 4L80E, DSE 4-Link, 9 inch, XFI with Traction control. Current status: suspension upgrades and paint ongoing
There is no such thing as too much power...The problem is not enough traction!!
Old Sep 17th, 10, 10:48 AM
Tech Team
How does the pinion shaft diameter effect the carrier or spool? Is the mounting flange for the crown gear on a different offset? Can you only tell them apart by the pinion shaft diameter?
Old Sep 17th, 10, 10:53 AM
big gear head big gear head is offline
Freddie
The ring gear flange offset is different. Everything else is pretty much the same. If you try to use a truck differential in a car rear end you have to do some shimming and sometimes some grinding to make it fit. Same thing if you go the other way.
Old Sep 17th, 10, 11:06 AM
Tech Team
A friend has a Vega drag car with a 12 bolt. We assumed it had a spool, but turns out, only has a posi. We are not sure which spool to buy. Because we have no history on this diff. Not sure if it is a cut down truck or car diff. How else can we tell?
Old Sep 17th, 10, 12:35 PM
Freddie
The 12 bolt truck rear end has a cover that is sort of shaped like a diamond on it's side. The car 12 bolt has a cover that is mosly round. If it has the Eaton Posi then there will be a casting number on the right side next to the bearing. Let me know what this number is and I can tell you if it's a truck or car.
This is the car 12 bolt.
Old Sep 17th, 10, 12:53 PM
Tech Team
It's the round car diff!! THANK YOU
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: What is the difference between 12 bolt car and truck carrier?
Location
Location
First Name
Human Verification
