Why won't this shifter work properly in my '68 Firebird? - Team Camaro Tech
Old Sep 28th, 10, 07:22 PM
tumbler510 tumbler510 is offline
Tech Team
Super 8
Default Why won't this shifter work properly in my '68 Firebird?
I have a Muncie M-21 hooked up to a 1975 Pontiac 400 in my 1968 Firebird, and can not figure out why this shifter won't fit into the stock hole in the tunnel. My shop had to cut out a hole in the side of the tunnel in order to fit the drive train into the car, but I would like to get the shifter fixed to the way it should be, weld a plate into the hole, and put new sound deadener and carpet in.
Here is the car, fresh out of the paint booth. 12 layers later...
Old Sep 28th, 10, 07:44 PM
Steiner Steiner is offline
Steiner
Default Re: Why won't this shifter work properly in my '68 Firebird?
It's the incorrect shifter for a first gen. The neck that the shift lever bolts to for a first gen is offset towards the passenger side. Look on the side case of the shifter body and there should be a part number there. I think the correct one is 3138. You'll also need the correct linkage/mount to position correctly and the Hurst part number for that is 3734529.
You need the correct shifter body, linkage/mount, and stick/lever to make it all work correctly with a console. The stick is not so much of an issue if you're not going to use a console.
You can purchase everything through Summit but it'll cost about $350 for everything. The shifter/stick combo is $230 and the linkage/mount is $125.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Sep 29th, 10, 06:57 AM
69Z28's Avatar
69Z28 69Z28 is offline
Gary
X2. I had 2 68 400 4 speed Firebirds and the shifter is the same as used in Camaro. No mods to the hole at all. Nice Bird dude. I like it.
"MY Z"
06A 1969 Camaro Z28
X33D80 69 B 711 Black Stripes
Console w/tach and gauges.
Old Sep 30th, 10, 06:17 AM
JOE58 JOE58 is online now
that is a "straight up" Hurst aftermarket shifter
You need the large offset shifter used in 1st gen Camaro Firebird
also need the correct installation kit
Click image for larger version
Old Sep 30th, 10, 06:37 AM
Andrew69's Avatar
Andrew69 Andrew69 is online now
Andrew
Hope you saved that piece of cut out metal so it can be re-welded back into place. Your 'Bird looks great!
Skunk Works
302DZ, M22W Muncie, 12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159 (Formally known as X33D80)
Old Sep 30th, 10, 09:14 AM
Everett#2390's Avatar
<Jake 68's Rule
It also looks like the trans is over to the drvr side a bit too much.
Check casting line of extension housing to tunnel ctr line.
Nice ride at any rate.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
