Vortec heads #10239906 - Team Camaro Tech
Old Mar 22nd, 05, 12:51 PM
Hobbes9112 Hobbes9112 is offline
Post
Have a chance to pick up a set of vortec heads and an edelbrock air gap intake for a pretty good price. I have heard good and bad about these heads. Are they worth buying? If so, what kind of cam would I need? Would I have to upgrade the springs? What kind of performance increase would I be looking at?
The block is a 350 bored .08 over (I already know this sounds crazy, but it is what I have to work with). I was going to use some 76cc cast iron heads and an edelbrock performer with a Comp Dual Energy cam #12-208-2. I don't know much about vortec heads and any suggestions would be greatly appreciated!
My work in progress: 1969 Camaro Coupe
If only tuition wasn't so high... this thing might be finished by now!
Old Mar 22nd, 05, 01:04 PM
DOUG G DOUG G is offline
RedЯuM
Post
Not sure about if the 906's are good or not. Vortec's are 64cc chambers and about 170cc runners. Really depends on what pistons (compression) and usage.
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Mar 22nd, 05, 01:15 PM
Post
I have the pistons that came with the block, but I am not really sure what they are. They are nearly flat, but that is about all I know. My Camaro is driven to shows, cruises, on dates etc., I don't plan to do any racing, but I want a good performing motor that can get up and go when a punk in a Honda pulls up next to me. [img]smile.gif[/img]
Old Mar 22nd, 05, 01:31 PM
67 Plum's Avatar
67 Plum 67 Plum is offline
Chad
Post
Hard to tell with out specs.You may have to much comp. with the 64cc heads.The 906 are good heads.
Old Mar 22nd, 05, 01:34 PM
RedЯuM
Post
Plum, thats where this looks like its going.
Hobbs,look up the piston numbers and go from there.
68 Camaro~ LSx
RedЯum <-Pics
Old Mar 22nd, 05, 01:42 PM
JimM JimM is offline
Jim
Post
if your pistons are the normal 4 eyebrow flat tops, use an .040 gasket and you'll be fine on compression if they are 64cc heads.
Old Mar 22nd, 05, 02:57 PM
kamero68 kamero68 is offline
Post
The 906 Vortecs were used on the heavier duty trucks and have pressed in hardend exhaust seats which makes them more durabale and resistant to cracking. The down side is, the machining mismatch of the pressed in seats with the bowl walls. The mismatch is miminal and can be blended but these heads dont flow quite as well as the 062s. But again, the difference is very, very slight. I would use them.
, the springs have around 70#s on the seat and if you want to run much more than .450 or so of lift you'll need to up grade springs and shorten the valve guides for retainer to seal clearance.
[ 03-23-2005, 12:25 PM: Message edited by: kamero68 ]
http://community.webshots.com/user/wsm9808
68 Camaro 505, TH400, 3.73, hyd roller, 049s
1/4 mile track----1.552---6.90/ 100.22---10.89/123.15
1/8 mile track----1.557---6.92/ 99.71
3500# , 2995 foot elavation
Old Mar 22nd, 05, 06:35 PM
Chris88Z Chris88Z is offline
Post
I love vortecs in every aspect. If the deals right scoop 'em up but be prepared to do some machine work if you want to use them in a performance motor. Have the guides cut down, upgrade the springs, and install screw-in studs. After you've done that you'll have a head thats capable of 11's with the right combo.
1988 Camaro
350 with out of the box Canfield 195's and Cam Motion solid flat tappet
11.50 @ 119mph 1.65 60' N/A
10.68 @ 126mph 1.51 60' 100HP
all through single 3" catback exhaust.
3490lb daily driven street car, never trailered!
Old Mar 23rd, 05, 07:00 AM
travis travis is offline
Post
The 906 casting is the only 350 vortec head I have ever seen. I've installed 2 sets and have a 3rd set here for another engine. None of my 906's have the bigger exhaust seat either. The thick exhaust seat, AFAIK, was only used on the 3/4 ton and larger truck 350's, not the 1/2 tons. Also, AFAIK, the only difference between the 062's and the 906 castings is that one was factory installed on the truck engines, while the other one was over the counter only.
One thing you need to check is the deck height of the pistons. A .030 flat top with 4 valve reliefs, .040 in the hole, with .041"x4.166" standard felpro head gaskets will yield 9.4-1 compression...perfect for a wide variety of streetable performance cams. If the block is 0 decked, your compression would be closer to 10-1...still plenty doable with the right cam selection. The vortec heads fast burn style chambers are much more detonation resistant than any old style head.
"This is not a cheerocracy...I make the cheercisions around here"
Old Mar 23rd, 05, 07:36 AM
Post
These heads are off of a 1997 k1500. How do I measure the deck height. That might be a dumb question, but this is the first engine I have ever put together.
Old Mar 23rd, 05, 09:02 AM
67 Plum's Avatar
Chad
Post
With the shortblock assembled you measure from the top of the piston to the deck surface with the piston at top dead center.
Old Mar 23rd, 05, 09:22 AM
Post
I guess I didnt know what I was talking about even with 20 years experiance working on heads for a living, but here is an article from CHP that seems to agree with my observations.
http://chevyhiperformance.com/howto/97458/
[ 03-23-2005, 12:34 PM: Message edited by: kamero68 ]
Old Mar 23rd, 05, 09:42 AM
Eric68 Eric68 is offline
Eric
Post
To measure dech height lay a straight edge across the deck and measure the distance between the straight edge and the top of the flat part of your piston when its at TDC.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro, E85 powered 427" small block. 9.96 @ 133 MPH, 1.319 sixty foot on motor. 5.92 eighth @ 116 with a 1.42 sixty breaking beams with back tire on the bottle
Old Mar 23rd, 05, 09:57 AM
BPOS BPOS is offline
Al
Post
Question:
Since the piston will rock in the bore, should you measure the high and the low and compute an average, or should you go with the smallest reading only? Or should you measure at the wrist pin centerline where piston rock has the least effect on the measurement? Thanks.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Mar 23rd, 05, 11:34 AM
Mkelcy Mkelcy is offline
Mike
Post
The "avoid the 906 Head" in the cited article turned out to be wrong information, that even Chevy Hi Performance backed away from. Turned out to be confusion about what the casting numbers meant. The best URL I could find explaining what went on was from Sallee Chevrolet's BB: http://www.sallee-chevrolet.com/Disc...tml?1089732160
Mike - Building a '68 Camaro with lots of stuff done to it.
http://img9.imageshack.us/img9/6301/img0372vm.jpg
