Power steering gear box - Team Camaro Tech
Old Oct 10th, 10, 05:49 PM
Walotka350 Walotka350 is offline
Tech Team
Default Power steering gear box
I have power steering on my 68 camaro, the lower seal leaks oil. is it possible to replace it, and do u have to take it off the car.
Old Oct 10th, 10, 05:52 PM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
Default Re: Power steering gear box
the lower square plate ?
BILL D.
JOHN 3:16
SEMPER FI
if you have a bbc in your 1st gen 67-69 camaro click on the link below and enjoy the veiw and post yours up!!
http://www.camaros.net/forums/showthread.php?t=169199
if you have an all original 1st gen camaro 67-69 click on the link below and enjoy the veiw and post your up!!
http://www.camaros.net/forums/showthread.php?t=179697
Old Oct 10th, 10, 06:00 PM
Tech Team
The lower round shaft it is a saganaw unit out of 72 Chevell.
Old Oct 10th, 10, 07:20 PM
irish420 irish420 is offline
Sean
they make a rebuild kit for it...I got one from napa.
Old Oct 10th, 10, 10:31 PM
speedfreak2 speedfreak2 is offline
Tech Team
WrenchingAce
There is a kit and it's called a "Sector shaft seal kit". The only problem is after you get the old seal out you will need to see is the sector shaft if worn too badly to hold a new seal.
Old Oct 11th, 10, 10:13 AM
go2fast go2fast is offline
Jim
I've done a few of these the quick and dirty way. Take the pitman arm and snap ring off, put a bucket under it, then start her up and crank the wheel hard to the stop. The pressure forces out the seal. Clean area and put in new seal. Like I said "quick and dirty", not a proper rebuild.
Old Oct 11th, 10, 10:27 AM
Tech Team
WrenchingAce
Exactly. It's worth it to try replacing the seal vs. buying a new/reman steering box. One extra step is after you remove the pitman arm, put the nut back on...just a few threads...that way when you blow the seal out you can see how the old one was installed. I suppose this will be your first one so hopefully that tip is helpful to you.
Old Oct 11th, 10, 06:23 PM
Tech Team
yes it is my first one thanks for the tip. Right now I have the eng. out. So you think I should wait and do this when the eng. is back in the car?
Old Oct 11th, 10, 06:45 PM
Tech Team
WrenchingAce
It would make the job a whole lot easier.
