Can a convertible top boot be painted or dyed? - Team Camaro Tech
Thread Tools Display Modes
Old Oct 11th, 10, 09:02 PM
69ndpce 69ndpce is offline
Wayne
Default Can a convertible top boot be painted or dyed?
Can a white 69 boot cover be painted or dyed? Say Blue, red, green or orange. I was wondering if there was anything that wouldn't peel off.
thanks
Old Oct 14th, 10, 01:15 PM
Daral Daral is offline
Daral
Default Re: Can a convertible top boot be painted or dyed?
SEM dye comes in a spray can and might do the job. Check Eastwood, they probably have it in several colors. I have used the black on my original black interior.
Daral (67 RS/SS 350)
Old Oct 14th, 10, 05:57 PM
Car nut Car nut is offline
I don't think you will get good results. I think it will peel/crack since it is a soft material and it will look painted or dyed. It would be fine on a hard surface. I would use the boot you have for a pattern and have a new one sewn if money allows. Just a thought, A tailor at a dry cleaner or of course an upholstery person. Good luck hope this helps. Brian.
1969 original SS in family since 1971.350/330 crate w/ comp 270 roller cam,2004R,355 12 Bolt posi,P/S P/FTD Brakes P/W P/TOP Orig A/C car but removed.
sold, my x 69
my 99 t/a vert I can murder w/o guilt
Old Oct 14th, 10, 06:43 PM
INPLUMSDEEP INPLUMSDEEP is offline
steve
I have used can spray dye on the head line of 1979 ford truck with great results also arm rest and sun visers.
Old Oct 14th, 10, 06:57 PM
SPARKY69's Avatar
SPARKY69 SPARKY69 is offline
BILL
99 bucks i vote for a new one?
BILL D.
JOHN 3:16
SEMPER FI
if you have a bbc in your 1st gen 67-69 camaro click on the link below and enjoy the veiw and post yours up!!
http://www.camaros.net/forums/showthread.php?t=169199
if you have an all original 1st gen camaro 67-69 click on the link below and enjoy the veiw and post your up!!
http://www.camaros.net/forums/showthread.php?t=179697
Old Oct 14th, 10, 07:21 PM
chops chops is offline
Greg
It is a paint and not a true dye. You have to use the prep spray first to "primer" the paint I mean errr dye for better adhesion.
I have not used it, but have read many result-type comments. About a split 50-50 for and against.....from "it has survived 4 years" to "it's peeling after 3 weeks."
I have a white vert top that should be black as the TT dictates, but I doubt I will waste time trying to paint I mean dye mine black; I just don't see how it can last with repeated flex.
1969 RS/SS Vert
1031 Engineering llc
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: Can a convertible top boot be painted or dyed?
Location
Location
First Name
Human Verification
