need some help decoding my numbers - Team Camaro Tech
Tag Team De-coding tags and numbers.
Old Oct 13th, 10, 11:48 AM
bigarmzz bigarmzz is offline
Default need some help decoding my numbers
i'm having some trouble decoding my numbers on my car (even with the "camaro by the numbers book")
here's my trim tag numbers:
ST69 12437 NOR 148877 BDY
TR 711 76B PNT
10C X11D80
the 10 on the bottom, cant make that out very well, appears to be a "1" in front of the "OC", cant tell for sure
does that top number need to correspond to the vin on my title? b/c on my title, the numbers are 124379N701668...??? thats whats on the dash as well
and the next question is the numbers on my rear end...i'm not so sure that maybe this rear could be from a different car such as a nova or chevelle, not sure
these numbers/letters were on the pass side front of my housing:
COZO320G2
E
i cant find any info in my book on those sets of numbers
oh, and the engine i bought on ebay awhile back, i finally got it and cleaned it up good, and was able to read the numbers on the block:
casting number on engine block is : 3956618 (got a buddy trying to tell me this is a 302 Z28 block) i think he's nuts b/c no DZ stamped on deck
19K456375 (stamped by the oil filter)
and
TO61O HB (stamped on deck surface)
i know the top number should start with 5..... not 4..... but it thats def whats on the blok by the oil filter
thanks guys, i know some of you know this info without even referrencing it
i tried to get pics of the deck surface numbers, but no matter what i did, they just didnt show, so here's what turned out-
block by the oil filter pics:
trim tag pic:
Old Oct 13th, 10, 01:16 PM
Default Re: need some help decoding my numbers
ok, i think i may have figured out my trim tag numbers now i believe it was originally daytona yellow with a black vinyl top, V-8, and with factory rear spoiler, assembled maybe in third week of october, which makes sense, b/c it was 701,668th down the line
but those rear end numbers, and the numbers on my block i got have me stumped
i believe that the HB code was for a 69 SS 350 camaro with a 350TH trans
Old Oct 13th, 10, 06:42 PM
Mark C Mark C is offline
Mark
The K stamping indicates the engine came from acar made in the Leeds Kansas assembly plant. Its not an original engine for this Camaro, but probably came from a Chevelle. The axle is a 1970 or later corporate axle as indicated by the three letter assembly code COZ. COZ is a 3.73 12 bolt posi axle for a 70 Camaro, it was assembled March 20th 1970 on the second shift at the detroit axle and gear plant. Again it is not original to this car.
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My Engine Compartment
Old Oct 13th, 10, 06:53 PM
wow....so i assumed a 70 rear end would be wider than that of a 67-69
also thought that since its a 69 block, and a HB code, that pretty much pointed at a camaro
...hmmmmm, thanks for that info, i really appreciate it...i honestly had no clue and couldnt find any info my self
Old Oct 13th, 10, 08:53 PM
buenymayor buenymayor is offline
This should help you out: http://www.camaros.org/drivetrain.shtml
Experience...... It's what you get when you didn't get what you wanted.
http://camaro.bertke-one.com/teamcam...%20Camaro.html
Old Oct 14th, 10, 06:57 AM
elcamino elcamino is offline
Mike
I agree, the con vin 19K456375 says the engine came from a 1969 Chevelle built at Leeds (Kansas City, MO) assembly plant.
No doubt about it.
Owned New
1966 Impala SS396
1970 Chevelle SS454
1972 El Camino SS350
1973 Chevelle SS350
1977 Monte Carlo
2002 Trans Am WS6
Old Oct 14th, 10, 08:14 AM
No doubt about it.
so this motor then b/c its a HB code is for a 69 chevelle, 350/300hp with a 350TH trans, right? thanks by the way for your input
Old Oct 14th, 10, 08:35 AM
Kurt S Kurt S is offline
Yup, Camaro and Chevelle and Nova all used the same engine code in 69.
Can you post or send me a pic of the HB stamping? Thanks!
Kurt S.
CRG - www.camaros.org
Old Oct 14th, 10, 10:43 AM
i actually took 4 pics of that, but none of them turned out at all....its like this motor is cursed, and just wants to maintain some "mystique"
Old Oct 14th, 10, 12:45 PM
Yeah, flash bounce can be a real problem. Natural light helps or even a trouble light.
Kurt S.
Old Oct 14th, 10, 01:21 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
Or if you have a "macro" button on your camera - try that. It may look like a flower icon for that setting.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
Old Oct 14th, 10, 10:33 PM
From the VIN pic he posted above, I assume he's got the macro thing figured out.
Kurt S.
Old Oct 15th, 10, 07:34 AM
bcm66's Avatar
Bryon / Big B
As usual, I think you are correct Kurt.
Old Oct 15th, 10, 09:49 AM
man this sucks! i bought this motor b/c it was supposed to be for a 69 camaro, now i find out its for a 69 chevelle
in the guys add on ebay he said it was an "N" on that vin stamp, not a "K"
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old Oct 15th, 10, 05:31 PM
