Installing a Rear Spoiler - Team Camaro Tech
Restoration Corner Where originality comes first
Thread Tools Display Modes
Old Oct 15th, 10, 03:40 PM
Davem Davem is offline
Dave
Default Installing a Rear Spoiler
I'm getting ready to install a rear spoiler onto my '68. Does anyone have any pointers before I start?? Thank you!
Old Oct 15th, 10, 04:33 PM
Nantooch Nantooch is offline
Brandon
Default Re: Installing a Rear Spoiler
Measure, measure again,, measure some more.. go back to start of last sentence and read through a couple more times. Now, then run some two inch masking tape across the deck lid and once you've figured out the measurements. Mark them on the tape with a pencil.. Go back to first sentence again, then look to see where holes will come through inside of deck lid. Prepare to have to drill or enlarge existing holes through secondary framing of deck lid.
Rear of spoiler should be approximately 3/8"-1/2" from rear edge of deck lid. Be very careful before and after drilling first hole and checking position not to scratch paint. If this is to be painted later still be careful of placement.
Brandon J. licence 1NASTY67
My 67 Camaro
Old Oct 15th, 10, 04:51 PM
zuma's Avatar
zuma zuma is offline
Mike, 69's rule
I made a cardboard template with the bolt holes...used small, superthin rubber washers around the bolts on the outside to make it waterproof...worked for me..good luck.
(STAY THIRSTY, MY FRIENDS).
1969 Camaro
1990 IROCZ28 convertible
2004 Silverado Z71 4x4
1981 Mazda RX-7
GGSMU member
http://www.ggsmu.com/
Old Oct 15th, 10, 04:55 PM
TraxUnderground's Avatar
TraxUnderground TraxUnderground is offline
Gary
I made an exact template of the spoiler stud holes using a thick costruction paper. Once I knew it was perfect I layed it on the lid and placed it where I wanted and measured the hole from the rear edge of the lid. If you move it too far forward the nut will not rest flat because of the contour under the lid. (at lease on my repo) I checked and checked over and over again. Then I taped to to the lid and looked at it for a while before I made any moves. Once i looked at it to the point i didnt know what I was looking at anymore I drilled the first hole. Once they were all done the spoiler sat perfect. This was before paint. Moral of my story is like mentioned above..check the template/measurments before you drill. PS the measurements in the diagram you see from Classic industries or one of the other suppliers doesnt mean it is correct for your spoiler. Aftermarket stuff is a crap shoot..so make your own template. Good luck!
Gary
67 RS Resto-Mod 468 5 spd TKO600 3.73 12 bolt (work in progress but finally on the road!)
http://s96.photobucket.com/albums/l1...=camaroRS1.jpg
http://s96.photobucket.com/albums/l164/traxunderground/
73 Camaro project in a million pieces
Old Oct 15th, 10, 07:10 PM
RamAirDave RamAirDave is offline
Dave
Use some type of seal around the mounting holes on the decklid so water doesn't enter into the trunk. I like to use a thin bead of windshield butyl.
Driving a #s-matching Z in the rain..... and lovin' it....
Old Oct 16th, 10, 05:46 AM
Paul68RS/Z28 Paul68RS/Z28 is offline
Paul
Make sure you find the exact center line for you spoiler and deck lid, to lay out the template or measurements.
I used the tape method listed above, and then put some blue valve marking compound on the spoiler studs to check for any deviation between my marks and the studs. It helped to have the center marked to make sure the spoiler was where it needed to be. I used a small bit (#30) first then stepped up the holes to final size with a reamer. I also use the thin rubber washers, works nice, no water in the trunk.
Paul
Old Oct 16th, 10, 09:41 AM
Dave
Good stuff... thanks everyone!!
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Restoration Corner      Current Topic: Installing a Rear Spoiler
Location
Location
First Name
Human Verification
