Rear end numbers decode please? - Team Camaro Tech
Tag Team De-coding tags and numbers.
Thread Tools Display Modes
Old Oct 19th, 10, 09:15 PM
K and K K and K is offline
Kevan
Default Rear end numbers decode please?
I pulled this ten bolt from a 67 Camaro, not sure if its the original. Ratio is 3.08:1
Stamped numbers on axle tube are
PE 0927G
D I
Cast numbers on pumpkin are
N
3894859
1248
Thank You
67 RS 540
(I haven't changed anything that can't be changed back)
Nicole: http://www.camaros.net/forums/album.php?u=42213
My build thread: http://www.camaros.net/forums/showthread.php?t=160602
Old Oct 19th, 10, 10:47 PM
YenkoSC YenkoSC is offline
Justin
Default Re: Rear end numbers decode please?
PE is a 3.08:1 posi
10-bolt
Casting Number: 3894859
Bolt Diameter: 3/8
Ring Gear Diameter: 8.20
Pinion Diameter 1.438
Axle Splines 28
0927: September 27th
G: Chevrolet Gear and Axle
It really confuses me that the rare "barn-find" in untouched and all original condition is the hot rodder's dream come true. It seems we love originality, yet we can't wait to destroy it.
1967 Camaro RS/SS 350
1969 Camaro LM1
Old Oct 20th, 10, 01:53 AM
Kevan
Thank you, is there a way to verify the year or just if it is original to the car? The cars build date is the second week of oct. 66'
67 RS 540
Old Oct 20th, 10, 08:45 AM
rafbody's Avatar
rafbody rafbody is offline
Russ
There will be a cast date on the webbing of the center section and if original gears, they will be dated as well.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
Old Oct 20th, 10, 09:54 AM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon
Yes, as just mentioned need the casting date.
But assembly date of 0927 seems good for a 10B car.
68 Camaro SS 396 - 468 BBC now, Air Gap Intake, 781 heads, M21, 12 bolt. 67 Chevelle SS 396.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Tag Team      Current Topic: Rear end numbers decode please?
Location
Location
First Name
Human Verification
