Need to ID a wire - Team Camaro Tech
Thread Tools Display Modes
Old Dec 5th, 10, 07:20 PM
MileHigh69's Avatar
MileHigh69 MileHigh69 is offline
Bob
Default Need to ID a wire
I just pulled my engine. After we noticed a wire coming down from the top of the tranny tunnel. It looked like the connector had been pulled off. However we could not find what it was connected to. We followed it up thru the tunnel where the shift lever is. Auto. It went up under the dash over to the steering column. Under the steering column is a black plastic thing with two connectors with two blue colored wires on them. Anybody know what this wire is for and what it connects to?
_______________________________
69 Camaro, Air Ride Suspension,
Procharged HO 454, 700R4, 12 bolt with Yukon axles, 3:73 gears posi, Pypes 2.5" X pipe with Borla XS mufflers. Retrotek Speed EFI, Ridetech suspension.
Rushforth rated X with Toyo tires. MSD 6 ignition.
Wilwood 6 piston Dynalite disc brakes with Hydratech booster.
Old Dec 5th, 10, 08:48 PM
flyingskibiker flyingskibiker is offline
cb
Default Re: Need to I'd a wire
Sounds like a neutral safety switch to me.?.? '68 uses different colors. The plug is in the same location near the steering column, though. Do you have a '69 AIM or wiring diagram? Wait, I just read a thread in the Electrical area about reverse lights and safety switch. It had a picture of the lower column and Everett mentioned blue wires. Do a little digging...
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
Old Dec 6th, 10, 08:14 AM
ss27 ss27 is offline
alex
Default Re: Need to ID a wire
very well ma be the neutral safety switch .you mentioned car had auto trans and led to trns tunnel could be also reverse back up lights i had a specific 69 camaro wiring diag but cant find it right now no doubt its where it aint supposedto be because i must have been thinkingof 47and a halfdifferent things when i put it away.this is what happens when you start to age the old CPU dont work like it did when you were 20 ,30 or 40. hope this helps AL ss27
Old Dec 6th, 10, 09:37 AM
BPOS BPOS is offline
Al
GM never ran a wire through the tunnel on an auto car for a neutral safety switch. Could it be the converter lock-up wire for your 700R4?
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old Dec 6th, 10, 10:25 AM
67 455 Bird ragtop 67 455 Bird ragtop is offline
Mark
Never mind ...
67 'Bird vert 455 JW TH400 KRE d-port 310 cfm heads H-beam rods Comp Cam 305-AH-8 cam w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Radials 31x18x15 on Convo Pro 15x15s
http://community.webshots.com/album/222472397caZdha
Old Dec 6th, 10, 05:07 PM
MileHigh69's Avatar
Bob
I dont think I have a converter lock up. I will get my schematic out and look it up. Thought somebody might know off the top of their head. Thanks
Old Dec 6th, 10, 05:21 PM
Everett#2390's Avatar
<Jake-68's rule
Could be the signal going to the trans to tell it to drop out of OD when brake is applied since an OD trans is an add-on.
Traced the wires back to where they originate?
I just thought of TCS- vacuum delay until in high gear?
Old Dec 6th, 10, 09:44 PM
MileHigh69's Avatar
Bob
Thanks Everett. Where would it connect on a 700 r4. I did not see a connection.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Electrical & Wiring      Current Topic: Need to ID a wire
Location
Location
First Name
Human Verification
