How to remove upper control arm shafts? - Team Camaro Tech
Old Dec 10th, 10, 08:19 PM
1320King 1320King is offline
Default How to remove upper control arm shafts?
How do I remove the upper control arm shafts for a 69 Camaro? I have removed the control arms from the subframe and they are on my work bench right now.
I want to replace the upper control arm bushings but it looks like I need to remove those shafts before I can press out the bushings.
Old Dec 10th, 10, 08:36 PM
Everett#2390's Avatar
<Jake 68's Rule
Default Re: How to remove upper control arm shafts?
Drill out the rubber part until there is none left.
Pull off the inner sleeve from the shaft.
Deform outer shell from arm.
Pull out shaft.
Remove the other bushing int he same matter - drill out rubber, deform outer shell.
Install new bushings - with shaft in place - grease shaft where inner bushing rides, antiseize is good, get a length of pipe to fit between A-arm on the outside of the bushing bores, press in place both bushings into arm, remove pipe.
Pipe is used to keep A-arm flanges parallel while pressing.
Might be able to use a large bench vise and sockets or pipe to press in bushings.
Don't forget the shaft.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Dec 11th, 10, 03:25 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
Once you have one bushing out the shaft will come out through that hole. Then the other bushing can be pressed out in one piece if I recall correctly.
Jeff
Old Dec 11th, 10, 06:02 AM
go2fast go2fast is offline
Jim
Unless you have a press, you might want to take it to a local auto machine shop where they will probably do it for $20-$30 per side.
Old Dec 11th, 10, 11:32 AM
tgifford5 tgifford5 is offline
Team Member
Ted
Use an air chisel. Pops em right out.
