saginaw 4 speed vs munice 4 speed in weight - Team Camaro Tech
Thread Tools Display Modes
Old Dec 17th, 10, 05:59 PM
jdbr1 jdbr1 is offline
John
Default saginaw 4 speed vs munice 4 speed in weight
can someone tell me the weigh differences between the saginaw 4 speed & the munice m21 thanks
Old Dec 17th, 10, 06:38 PM
dondb's Avatar
dondb dondb is offline
Don
Default Re: saginaw 4 speed vs munice 4 speed in weight
Just took out a saginaw and put in a muncie m20...i never weighed them but from carrying them it has to be at least a 25+ difference. I know the saginaw is made of steel and the muncie aluminum.
69 X-44 Camaro, slowly upgrading to my liking...Hmmm, i guess i'll never be done
http://www.camaros.net/forums/showthread.php?t=251593
2002 Camaro LE SS...Many upgrades
Old Dec 18th, 10, 09:22 AM
Melrose RS Melrose RS is offline
Tom
If you are considering switching to the muncie because it's lighter, based on that alone, the advantage would be negligible. Strength, yes, the muncie has it. For a cruiser like mine the saginaw's one advantage may be that you have more gearing options due to a wider range of gear sets.
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
the Melrose rs - L30 327/275hp
Old Dec 18th, 10, 09:56 AM
Andrew69's Avatar
Andrew69 Andrew69 is offline
Andrew
I think the Muncie weighs about 85 lbs and the Saginaw weighs about 120 lbs or so.
Skunk Works
302DZ, M22W Muncie, GV overdrive,12-Bolt Rear 3.73
Some photos: http://www.camaros.net/showroom/show...0&ppuser=11587
Member # 159
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Transmission & Driveline      Current Topic: saginaw 4 speed vs munice 4 speed in weight
Location
Location
First Name
Human Verification
