Heater Core - Team Camaro Tech
Heating & Cooling Heating, cooling and air conditioning
Old Dec 26th, 10, 03:15 PM
67 4 me 67 4 me is offline
Team Member
Randy
Default Heater Core
So I finish the install of my new stroker motor (see previous post) and I take it out today to put some miles on it. As I'm cruising, I start to smell that unmistakable scent of anti -freeze (heater core dripping).Luckily,I'm just a few blocks from my local Carquest. I bought a heater hose bybass nipple and I'm back on the road. I've changed several heater cores in my life, but never a 67 camaro. Is there anything special I need to know? does it come out in the car, or does it come out through the engine bay once I remove the cover on the firewall? I'm guessing someone has already posted a "how to" on this site if anyone can re-direct me.
Thanks Randy
Click image for larger version
Old Dec 26th, 10, 03:48 PM
Lucky68's Avatar
Lucky68 Lucky68 is offline
Mike
Default Re: Heater Core
Here's a good write-up I found with pics. It's not a fun job since the heater box is so tight with the inner fender.
http://www.camaros.net/forums/showth...re+replacement
1968 Camaro Coupe: Forged 383, AFR heads, Edelbrock Air-Gap intake, Holley 750 dp, Dynatech headers (557 HP/543 TQ), TKO-600, 12 Bolt 3.73, Vintage Air.
http://rides.webshots.com/album/250023748XWhfQW
Old Dec 26th, 10, 03:49 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
Awesome engine compartment.. Heres a good link step by step http://www.camaros.net/forums/showth...r+core+install
I NEED TO HIT THE LOTTERY
Old Dec 26th, 10, 03:50 PM
Skeeter55's Avatar
Skip
X2 Mike
Old Dec 26th, 10, 04:18 PM
JR67RS JR67RS is offline
John
I just removed my heater core. You have to remove the pass inner to get it out for sure. You may even have to unbolt the bottom fender bolts to give yourself some room to get it all out. See my thread on new engine. You will never get to the nuts tucked in the corner with the inner in.
Old Dec 26th, 10, 07:41 PM
Fred Mertz Fred Mertz is offline
Dave
I replaced my small block core with a big block core. I got the measurements for the new holes from an original big block car. I drilled holes in the box cover with it still in place. Project worked out simpler than I expected.
The biggest part of the project was removing the center console in order to remove the old heater core.
Dave
Runs with scissors....
__________
1969 Camaro Z/28 "Wannabe only better", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:42.
Old Dec 27th, 10, 06:53 PM
Mark Rossiter Mark Rossiter is offline
Mark
What?? I have replaced the heater core on my 67 several times and have never had to touch the fenders. Read the write-up cited by Skip and Mike; it's all in there. Takes some time, but is not difficult.
1967 Plain Jane Coupe - and proud of it!
Mountain Green w/Black Bumblebee
Old Dec 27th, 10, 07:27 PM
Sauron67MM Sauron67MM is offline
Scott
I could be wrong but I think he meant yanking the cover as well with whatever method he is using. In his thumbnail it appears a block off plate is being fitted. But yes, the core is changed from inside the car.
Old Dec 27th, 10, 08:17 PM
rogerh rogerh is online now
You don't need to remove the heater box on the engine side of the firewall. It is hard to reach some of the nuts that need to be removed on the engine side but you can get to then without removing the inner fender. All the rest of the work is done from the inside after those firewall nuts are removed.
When its time to put it back together its nice to have a helper on the engine side with some 1/2" dowel to line up the heater core pipe going through the firewall. On the inside you will be fighting the firewall insulation pad and lining up all of those studs on the inside heater box. Good luck with your project.
Roger
1967 Camaro SS/RS 350/295HP Coupe. First and only owner.
Old Dec 28th, 10, 12:55 PM
Lucky68's Avatar
Mike
On a side note, be careful of which new heater core you choose. A lot of people have complained about ones made in Mexico which are a poor fit and quality. I've heard of some guys having their old one re-cored by a radiator shop.
Take your time reinstalling the core as it's a tight fit and a bit awkward getting the tubes to fit through the firewall. You don't won't to crack a tube and end up with it leaking again.
Old Dec 28th, 10, 01:23 PM
John
Sorry guys I miss read the thread. I removed everything including motor, fan. I had to make some room to get the cover out off the firewall. No you don't have to remove the inner.
Old Jan 1st, 11, 02:13 PM
kevinkane kevinkane is offline
kevin
Randy, I just replaced the heater core on my 68' 327 with a/c. Leave the fenders alone. Heater box comes out from inside the car. Not a fun job! The hardest part was finding a heater core replacement that actually fit. Do not use Ready-Aire brand replacements. I went through three of them. None fit. Nothing like making a hard job harder. I eventually had my local radiator shop repair my original. Not a bad thing to consider. Might save you a lot of aggravation. By the way...sweet looking engine compartment!
