EFI on 327 - Team Camaro Tech
Old Jan 7th, 11, 04:36 AM
kgmunro kgmunro is offline
Ken
Default EFI on 327
Hey guys can a guy install 92 style heads on an older 69 327? I have a 350 from a 92 camaro (tpi) with a siezed bottom end and want to put the efi on my 327 short block...any problems known??
Old Jan 7th, 11, 01:10 PM
Vintage 68's Avatar
Vintage 68 Vintage 68 is online now
John
Wink Re: EFI on 327
If it is an L98, the parts will bolt-up.
Of course getting the system and sensors mounted and working correctly will take time and some fiddling ...
Get a good book, like "TPI Fuel Injection Swapper's Guide" and read up on it before you take this on.
This is not a 'Rocket Surgery' type task, you just need to know and understand how the system works and what the ECM need to know to operate correctly.
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jan 7th, 11, 08:30 PM
67YenkoJC 67YenkoJC is offline
Team Member
Jason
Default Re: EFI on 327
+1 John,
Also, make sure you have the heads checked for cracks on that siezed up engine, could be a sign of ran wayyy too hot. If they turn out to be junk, find yourself a cool set of L98 Corvette aluminum heads
1967 Camaro Yenko Pro Touring Tribute (being built)
http://www.camaros.net/forums/showthread.php?t=178571 Follow my build
Old Jan 8th, 11, 03:29 AM
Ken
The engine dropped the oil pump when idling in the lot. It was my friends motor. He shut it off right away.
Old Jan 8th, 11, 11:45 PM
wiskeesour's Avatar
wiskeesour wiskeesour is offline
Harley
Swap the entire motor. I would bet a Dr pepper that the TPI motor would be OK after some fresh bearings. Heck yeah, swap the whole motor. Save that 327...just in case.
Swap whole motor and it would be a little easier swap. I did that EXACT same swap in a 69 about 15 years ago before all the razzle-dazzle of EFI now-a-days and it wasnt much effort at all to get it swapped and running. Even installed a JET chip, thermostat and recommended comp cam. It got 22-24MPG at 65 and would run 11.90-12.10's and that was driving 1.5 hours to the track and racing then driving it home...lol to kewl.
AE2(AW) Harley Moody, USNavy
"Master-at-Arms" for the CDWJB!!
November 26th, 2008 was my last day to serve my country as a member of the World's Greatest Navy.
Thanks Chief.
