327 2bbl thrashed my crossmember - Team Camaro Tech
Camaro Tech General Tech Area
Old Jan 14th, 11, 10:51 PM
kettbo kettbo is offline
George
Default 327 2bbl thrashed my crossmember
I have been gutting my 68 vert the last few days. Scraped a lot of grease off the crossmember today. I found the crossmember layers separated for the most part. Then I looked close, saw this!
Has anyone seen anything like this....327/210 and Glide with 2.73 gears
So far as I can tell this Vert has been a cruiser its whole life....
If you're running a Fat Boy, 4-spd, DRs/slicks, then ya may want to look at your junk
George Kettler
o 70 Elky 454/3000 stall/3.42 gears
1.632 60ft, 11.726 ET, 113.49mph
o 68 Vette 427/M-20/3.36 mine 22 years this Fall
o 68 Camaro Rallye Green Vert 327/210 http://www.camaros.net/forums/showth...183654&page=52
Old Jan 15th, 11, 06:39 AM
Melrose RS Melrose RS is offline
Tom
Default Re: 327 2bbl thrashed my crossmember
That's odd! I wonder if the car could have been driven over something or somebody tried to jack up under the crossmember?
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
(And an 8 year old riding shotgun. )
the Melrose rs - L30 327/275hp
Old Jan 15th, 11, 07:02 AM
Everett#2390's Avatar
<Jake 68's Rule
Drill a hole in the end of the crack and weld it. Old crack, may have been improperly spot welded at time of manufacture.
Give a man a rescued dog for the health of his soul.
Two little words - Yes and No - require the most thought.
Other stuff: http://www.flickr.com/photos/everettwn68
Old Jan 15th, 11, 07:10 AM
john68 john68 is offline
John
The awsome power of those 2 bl's, makes me thankful I changed to a 4 bl. years ago.
Old Jan 15th, 11, 07:24 AM
clill clill is offline
Charley
Might be someone drove around with a broken motor mount for awhile.
Old Jan 15th, 11, 04:05 PM
George
This pretty well explains some clunking I have felt....that and cutting off the old exhaust!
Unsure how it happened but I'll get it fixed. Quite a shocker!
George Kettler
