Repo 621 Bellhousings - Team Camaro Tech
Camaro Tech General Tech Area
Old Jan 18th, 11, 09:34 AM
cwb90 cwb90 is offline
Team Member
Clint
Default Repo 621 Bellhousings
Can someone tell me if the fit / quality of the reproduction 621 bellhousings are any good? I see Classic Ind. has a heavy duty version and regular one so I'm somewhat confused on which one to get and whre to get it from. I see ebay has a bunch listed but I'm not sure of the quality. Thanks for any help,
Clint
Old Jan 18th, 11, 10:25 AM
zman1969 zman1969 is offline
Rich
Default Re: Repo 621 Bellhousings
Keisler makes a H/D alum/Titanium alloy thats CNC made and supposed to be spot on - I was planning on one of them the regular repop stuff always seems to be poor quality(fenders, quarters door panels and the like - why would a repro bellhousing be any better?)
69 R/S Z/28 302 4.10 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
69 Nova SS retirement project
99 Firehawk
64 Chevelle wagon 6.0l planned sons toy
Old Jan 18th, 11, 07:28 PM
Steiner Steiner is offline
Steiner
I've got the Keisler one but haven't really heard anything bad about the reproduction ones. FYI run out of the bellhousing on my Dart block was 0.0035" against a 0.005" maximum recommended but then again...new block and new bellhousing you would assume that core shift would be minimal. It needs to be checked regardless.
Don't quote me but I think the heavy duty 621 that Classic sells is actually the Keisler bellhousing. It does not show "discount exempt" in the catalog so if you can use the 20% off coupon on it that's the way to go.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Jan 19th, 11, 08:35 AM
zdld17 zdld17 is offline
Don
Got my 621 repro from Classic years back, it was beefy. Dialed in perfect within .003 compared to my old Lakewood .045. I feel just as safe using a billet flywheel without the scatter shield.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
Old Jan 19th, 11, 09:08 AM
68 Ragtop 68 Ragtop is offline
James
I have the heavy duty reproduction 621 bellhousing and it fit/functions well.
The bellhousing is a structural member of the drivetrain and I have seen quite a few original ones that are cracked, so it just makes sense to go with the heavy duty repro one.
BELLHOUSING - Keisler designed & manufactured reproduction of the 11 inch '621' bellhousing. Made in USA of high strength cast aluminum-titanium construction, 50% thicker wall construction than factory, CNC machined; available for all Chevy V8s and GM LS engines.
rszmjt rszmjt is offline
Mike
Do You? FWIW - It is not allways the flywheel that explodes, watch the vidieo link below to see what happens when a Pressure Plate Explodes.
1994 Lumina Z34, 2655lbs. 446" Small Block, Brodix Canted Valve, lenco 5 speed, 8.21/167 Best. New Bickle Cavalier, 1810lbs for 2010. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
Old Jan 19th, 11, 03:00 PM
DT DT is offline
Donny
That was sick!
396 X66 LeMans Blue, M20, 373 ...
Old Jan 20th, 11, 03:00 PM
re-living 68 re-living 68 is offline
Team Member
Don
I bought the replacement 621 from Ground Up and it fit fine.
Old Jan 20th, 11, 03:12 PM
Vintage 68's Avatar
Vintage 68 Vintage 68 is online now
John
Wink Re: Repo 621 Bellhousings
Originally Posted by rszmjt View Post
... watch the vidieo link below to see what happens when a Pressure Plate Explodes.
that was the Clutch Disc that exploded and took the PP with it ...
Disc explosion or failure is a much more common failure than Flywheel or PP.
Specially if a disc is abbused with bad driving habits
1968 Convertible
Some trucks
Other V8 things - some of which float
Other V6 things - none of which float
Oh yeah, and 1 "Straight-Six" ...
If a man says something in the garage - and his wife can't hear him - is he still wrong !!!
Old Jan 20th, 11, 06:05 PM
Steiner
What?! You can't do a 6000 RPM clutch drop on an old LS1 factory clutch hooked to a Z06 engine?! Must be those crappy parts GM has made in Mexico.
I remember seeing that video a while back. If a piece of it had hit the guy in the head it might've been an improvement.
538 lb-ft - 500 hp
www.cmengines.com
Old Jan 20th, 11, 07:50 PM
bcm66's Avatar
bcm66 bcm66 is offline
Bryon / Big B
I saw that video a while back too. That guy was an idiot.
Scatterproof bellhousing with a block saver plate is the only way to go if you are going to race.
68 Camaro SS 396 - 468 BBC now, M21, BO coded 12 bolt - but currently has 3.31 gears and a posi. Old drag car back on the street.
Looking for 68 Camaro with body number NOR 181016
CRG - www.camaros.org
Old Jan 21st, 11, 05:53 AM
Don
YouTube - Death of a Trans Am
I don't use cheap clutches and its a new assembly at ever tear down, need it or not but I understand your comment.
Don
TC # 349
