How to remove rear seat 69 - Team Camaro Tech
Thread Tools Display Modes
Old Jan 27th, 11, 07:44 PM
Red Reaper Red Reaper is offline
Tech Team
Kristin
Default How to remove rear seat 69
Going to remove the rear seat bottom on my 69 SS non folding rear seat to install new carpet and seat belts. How do I get the bottom cushion out? does it bolt or snap in place?
Old Jan 27th, 11, 07:51 PM
Steiner Steiner is offline
Steiner
Default Re: how to remove rear seat 69
It just snaps in. Feel under each side and there's a little bracket on the floor. The metal frame slides into it. You should be able to see them once you pull the front seats out and can get your head in there. You pretty much have to get in a four point stance and push it backwards like you're driving a blocking sled. It'll spring backwards a couple of inches and then up out of the bracket. Cursing a lot helps also.
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Old Jan 27th, 11, 08:00 PM
Yellow camaro Yellow camaro is offline
Tech Team
68
Push up slightly and with your knee kick the seat back and it should pop right out...
Old Jan 27th, 11, 09:29 PM
Steptoe Steptoe is offline
Steps
If it has not been out for decades....it will not pop up as easy as the guys above say.
you should be able to look under with the front seat out to see how it unclips.
BUT it is always easier to push real hard rearwards and down to un clip IF the front seat is still bolted in so you can use that to put your weight against
Push on the bottom steel edge about 1" in from where it curves at each side.
you weill feel it 'give' push back...then at the same time sort of push down and up...
If you do not get a sweat up you are not pushing hard enough..I mean that literally
So it all sounds a mission, but once you do have it out it sort of..."hmm now I see it in the 'daylight' thats no big deal"
Old Jan 27th, 11, 10:27 PM
Mkelcy Mkelcy is offline
Mike
In addition to the helpful posts above, I've always found that copious cursing made me feel better when the seat refused to move.
Mike - '68 Camaro with lots of stuff done to it.
http://imageshack.com/a/img745/1637/0NP8Y4.jpg
Old Jan 28th, 11, 12:47 AM
freezined freezined is offline
Ed
This may help, I've never been able to pop them out as easy as he makes it look.
Old Jan 28th, 11, 06:45 AM
Tech Team
Kristin
Thank you!! I'll give it a shot later on this weekend. Maybe I'll find something behind there. Always wanted to find the factory printout sheet, but I know it's had interior put in it several times. Thanks again!
Old Jan 28th, 11, 08:11 AM
click's Avatar
click click is offline
Moderator .. Jim
Jim
Wish I had a close up but you can see the 2 reverse slotted parts on the floor in this pic, below the orange arrows. The seat frame steel bars slide into those slots and drop down to more or less lock in. Push backwards and up at the same time, knees come into play here, and it should release. Its a pain but doable.
I blew that part up now, hope this helps you see what you cant see under the seat.
Click..is Jim..former owner of a 69RS-LM1 350/255 - 700r
Photos of my Camaro for viewing
Old Jan 28th, 11, 11:26 AM
Tech Team
Kristin
Perfect!! thanks!!
Old Jan 28th, 11, 12:29 PM
Nashville Beth's Avatar
Nashville Beth Nashville Beth is offline
Banned
Bethanne
X2
  #11
Old Jan 28th, 11, 01:48 PM
Kelley Kelley is offline
Tech Team
Kelley
Amen
  #12
Old Jan 29th, 11, 07:06 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
Originally Posted by Kelley View Post
Amen
So you're saying prayer is just as effective as swearing Kelly?
Jeff
  #13
Old Jan 29th, 11, 10:27 AM
MTN10 MTN10 is offline
Jeremie
Default Re: How to remove rear seat 69
The first time I ever tried to get my seat out was so frustrating. Probably would have burned the car down but it was in my garage.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Interiors      Current Topic: How to remove rear seat 69
Location
Location
First Name
Human Verification
