350 bypass hose - Team Camaro Tech
Old Jan 28th, 11, 08:33 PM
joels's Avatar
joels joels is offline
Team Member
Joel
Default 350 bypass hose
Do I have to run the bypass hose from waterpump to intake or can I just plug the intake hole and run top wp hole to heater core? What problem could this cause to the engine?
Old Jan 28th, 11, 08:48 PM
Steiner Steiner is online now
Steiner
Default Re: 350 bypass hose
The bypass on a 350 is on the block. It's the lower hole on the passenger side of the water pump. If you want heat, you need the water pump connected to the heater core and the passenger side port on the intake connected to the other leg of the heater core. The port on the driver side of the intake is typically used for a temperature sensor.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Jan 29th, 11, 06:24 AM
joels's Avatar
Team Member
Joel
Okay, so the 4'' hose from WP to intake does not have to be connected? I can just put a plug in the front hole on the intake
