Power brakes booster.. - Team Camaro Tech
Old Jan 29th, 11, 04:16 PM
Speedjester Speedjester is offline
Hector
Default Power brakes booster..
Well I have a 68 camaro with disk in the front and drums in the rear...and a a manual master cylinder... So the question is how difficult is it to switch to power brakes... What is need... and would installing a power brake booster help with braking on my set up." thank you
Any help with info would be appreciated
Old Jan 29th, 11, 04:21 PM
JR67RS JR67RS is offline
John
Default Re: Power brakes booster..
Booster, master and p valve. Many vendors have the upgrade kit. shop around.
Old Jan 29th, 11, 11:25 PM
z28andrs z28andrs is offline
You'll need also a longer pushrod for power brakes.
Old Jan 30th, 11, 05:07 AM
Sauron67MM Sauron67MM is online now
Scott
P. valve is on the subframe, Hold-off or metering valve in under the MC, if this is what you meant. The vendors don't know what they are called or what their function is.
