Ralley stripe dimensions - 69 Camaro - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Feb 6th, 11, 12:40 PM
69Z28LEXIE 69Z28LEXIE is offline
Lexie
Default Ralley stripe dimensions - 69 Camaro
Hi, my name is Leixe, I am new to the forum. My husband and I (mainly my husband) are working on restoring a Z28 69 Camaro for me. I am planning on painting it black with cortez silver ralley stripes. I currently have it in the body shop awaiting paint. Does anyone know the correct dimensions of the ralley stripes, including pin stripe widths and gap between pin stripes and stripes. Thanks
Old Feb 6th, 11, 12:51 PM
98blackburb's Avatar
98blackburb 98blackburb is offline
Banned
Alan
Default Re: Ralley stripe dimensions - 69 Camaro
http://www.stencilsandstripes.com/pr_chev_cam.asp
http://www.phoenixgraphix.com/index.htm
Old Feb 6th, 11, 12:52 PM
Banned
Alan
http://www.phoenixgraphix.com/gm/cam0006.htm
Old Feb 6th, 11, 03:43 PM
69z28freak's Avatar
69z28freak 69z28freak is offline
Mike
Hi Lexie here is a diagram for the 69 Z 28 Stripes. Outer pinstripe should be 9/32's wide and the gap between the pinstripe and the wide stripe is 9/32's. Use the lower diagram as the top is for a '67 or '68.
I used the Stencils and stripes kit and it needed to be modified quite a bit. The only usable parts were the rounded corner parts that go on the cowl and the rear panel. The rest of the stripe get laid out by hand using tape. Also note that in the kit it says that one of the stripes on the rear is wider than the other. I made mine the same width. Also note that you should have the emblems in place to make sure everything is in the correct spot.
A few questions are. Did you car come with stripes? If so you can use the old stripes as a template. If not are you going with the late or early design. Early Z 28's came with a '68 rear spoiler and '68 rear stripes that are closer together on the rear deck. The later design with the '69 spoiler had the stripes moved wider apart.
I will check and see if my shop took pictures of the stripe laid out on the car. Also note that my shop told me that it was much tougher and time consuming that originally thought, which added conciderable cost and time to the project. The better prepared you are or if the shop has done these stripes before will greatly reduce the cost to apply them. The entire car needs th get masked off several times in the process and also parts need to be removed once the stripes are laid out, ie; the hood, cowl, trnunk lid and header panel. I think you could paint the car with those parts on, but my shop thought they could do a better job removing them.
Good luck.
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
http://www.camaros.net/forums/showth...ght=69+grandma
BC Camaro Club
http://www.bccamaroclub.com/#!builds/c8ky
The Rod & Custom Shop
http://www.therodandcustomshop.com/
Old Feb 6th, 11, 04:11 PM
Sauron67MM Sauron67MM is offline
Scott
If you want to know what just one car looked like originally here's a link to James' survivor. http://good-times.webshots.com/album/568034888OhHzjB You can clean the edges up if you are not trying to obtain 100% originality. As you are shooting your stripes silver it is apparent you are not. Many stripes are done incorrectly, in the jambs and dimensionally. And if an original D80 car or not. Do your research, as many repaints are not good reference.
Old Feb 6th, 11, 06:39 PM
Mark C Mark C is offline
Mark
http://www.camaros.net/forums/showthread.php?t=10763
http://www.camaros.net/forums/showthread.php?t=84805
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My Engine Compartment
Old Feb 7th, 11, 08:06 AM
yellow69RS's Avatar
yellow69RS yellow69RS is offline
Jeff
The diamensions above do not match the information in the AIM. (I don't think they match his car either) Aim shows outer pinstripe to be .25 and gap between to be .38.
Jeff
Old Feb 7th, 11, 08:02 PM
69z28freak's Avatar
Mike
Jeff
Hey Jeff you are correct. I wonder where I got that info from? I think that the Stencil kit shows the same diagram as the AIM. Also some of the links posted show some really great detail and information. I wish I would have done the search before doing my stripes. I won't know until I measure mine, but at a glance they look correct.
My Build Thread
BC Camaro Club
Old Feb 8th, 11, 08:26 AM
yellow69RS's Avatar
Jeff
9/32 sounds about the right size for the pinstripes on the fenders of my RS. Option code D96. Don't know if that's where or not. The pics of your car look to be the correct dimensions for the stripes on the hood and deck.
Jeff
Old Feb 8th, 11, 03:57 PM
Lexie
Thanks for the great info and the diagram.
  #11
Old Feb 8th, 11, 04:41 PM
69z28freak's Avatar
Mike
Jeff
Thanks Jeff. That is good to know.
My Build Thread
BC Camaro Club
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Ralley stripe dimensions - 69 Camaro
Location
Location
First Name
Human Verification
