68 camaro brake line? - Team Camaro Tech
Thread Tools Display Modes
Old Feb 11th, 11, 05:34 PM
Speedjester Speedjester is offline
Hector
Default 68 camaro brake line?
I need to replace the line that goes from the master cylinder to the rear axle... It is a one piece unit...but I see thet several places sell them in 2 configurations.. One long line or two lines you join... Is there a reason to go to the 2 piece unit... Any difference other than the obvious...
Thanks in advance
Old Feb 11th, 11, 05:38 PM
john68 john68 is offline
John
Default Re: 68 camaro brake line?
The rear hold off valve, under the drivers seat,
Old Feb 11th, 11, 05:47 PM
Hector
I have front disc with a manual master... And a straight one piece line from the master to the rear axle... Should I replace it with a two piece and a hold off valve... Car seems to stop straight... I do have to push pretty hard but hope to change it to power down the line.. But for now need to address the line as it was cut and repaired with a pressure fitting...
Any thoughts
Old Feb 11th, 11, 05:53 PM
John
You don't need the hold off valve, you can use th 2 peice with a coupler, or a one piece
or bend your own line, If you mean a compression fitting, yes it needs up grading.
Old Feb 11th, 11, 05:57 PM
Hector
Great.. I will order the one piece unit...I would make my own but there does seem to be some tight bends... And yes I meant compression fitting... Body shop cut the line when doing the floor..
Thanks for the info...
Old Feb 11th, 11, 06:01 PM
BPOS BPOS is offline
Al
The hold off valve (metering valve) is mounted at the MC. The one on the frame rail is a proportioning valve.
Most 1st gens (yours included) did not have the frame mounted prop valve.
If there is nothing wrong with the current line other than the compression fitting, I would just double flare each end at the cut and install a brass flare union there. I would not trust a compression fitting on a brake line.
If you want to replace the line with a new one - it's your call. Thats a pretty handy spot to mount an adjustable or stock prop valve. Or you could install a flre union there. I would think a 2 piece line would be easier to install.
Or do a one piece line.
69 PJ Convert, RS added, 383, Pro-Filer 195s, 2004R, 3.73 posi 8.5, C6/LS1 Brakes, etc "Big hitter, The Lama....long." Carl Spackler
Old Feb 11th, 11, 06:06 PM
John
Speed, thats not as bad as, in about 91 worked a Chevy dealer, we had a custom van,
raised roof, custom rear bench, and a wheel chair lift, etc. The van had no rear brakes
we did every thing, they would not work, finally found the wheel chair lift co. drilled thru
the brake and fuel lines, they repaired with vacuum hose and a couple of clamps. When
the brakes were replaced it looked like a snake had eaten a rabbit.
Old Feb 11th, 11, 06:07 PM
Hector
I thought about re flaring... But the line did look pretty rusty...thanks
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: 68 camaro brake line?
Location
Location
First Name
Human Verification
