For those who converted to LS1 brakes - Team Camaro Tech
Old Feb 11th, 11, 08:30 PM
shadys69 shadys69 is offline
mike chiarito
Default For those who converted to LS1 brakes
I have a couple of questions for you.What did you use for front brake lines?Can some one post some pictures please and also what front wheels are you guys runing and fitment ishues?Thanks
TEAM CAMARO SS CHICAGO
Old Feb 11th, 11, 09:11 PM
BPOS BPOS is offline
Al
Default Re: For those who converted to ls1 brakes
Even though I didn't use the LS1 fronts, I can answer your question on brake lines. The caliper uses a banjo fitting, and there are probably a number of companies that make flex lines that will connect to your factory hard lines with the correct banjo fitting for the caliper. In fact, I believe the C5 and the LS1 use the same banjo fitting. Here's where I got mine - the price is very reasonable I think. http://www.kore3.com/products.php?cat=20
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler
Old Feb 11th, 11, 09:33 PM
mike chiarito
Do u have any pictures?R u runing c5 calipers?
Old Feb 11th, 11, 10:51 PM
Al
C6 now, but originally C5. These are the only photos I have showing the brake lines.
Old Feb 11th, 11, 11:50 PM
tgifford5 tgifford5 is offline
Team Member
Ted
Al I see you have adjustable upper control arms> Are they SPC's? Are you hitting the subframe? It looks awful close. I just installed mine but I have no motor or tranny in the car and mine are touching.
Old Feb 12th, 11, 12:15 AM
Al
It's possible - that's an old picture, and the susp was probably just hanging there. They have never hit while driving the car that I know of. (yes - SPC)
Old Feb 12th, 11, 07:06 PM
MSCHMIDT9090 MSCHMIDT9090 is offline
Mike
It has been a while since I did my conversion, but I believe the factory ls style hoses will mate to the original hard lines without any issues.
Mike
68 Camaro SS396
http://s209.photobucket.com/albums/bb121/mschmidt9090/
Old Feb 12th, 11, 08:35 PM
mike chiarito
Any one else? Pictures of how you routed and mounted the hoses would be great.
