My experience with Blueprint engines - Page 2 - Team Camaro Tech
Thread Tools Display Modes
  #16
Old Mar 3rd, 11, 02:09 PM
BThomas327 BThomas327 is offline
Brad
Default Re: My experience with Blueprint engines
Hey Vamber. I am doing the base engine because I have my own intake, carb, and the rest. Plus I am trying to dress mine to look like a 302. That's very doable with the exception of the passenger side dip stick. Not much I can do about that. As for the heads other than the obvious differences I couldn't tell you much between the aluminum heads and the Vortec Heads. I do believe you get an extra 15 hp and 30ft-lbs of torque with the aluminum set up. I read that someone looked up the part # I gave BP38313CT1 and couldn't find it. You would have to go to the summit website and put it in. Like I said before it's a new product so you can't find much on it. It does have a hydraulic roller cam which was important for me. I have a feeling that eventually the flat tappets are going to have to go away with the inferior lubricating properties of today's oil. Other than Rotella T that is.
Old Mar 3rd, 11, 06:11 PM
Nashville Beth's Avatar
Nashville Beth Nashville Beth is offline
Banned
Bethanne
Originally Posted by BThomas327 View Post
Hey Vamber. I am doing the base engine because I have my own intake, carb, and the rest. Plus I am trying to dress mine to look like a 302. That's very doable with the exception of the passenger side dip stick..
Hi Brad,
I admit I was bored, so I found you a correct looking oil pan for $67.
Now American Idol is on ! Good luck....
http://www.summitracing.com/parts/MRG-9425/
  #18
Old Mar 3rd, 11, 08:15 PM
Steiner Steiner is offline
Steiner
As soon as they start putting cats on all diesels and make the automakers warranty them like they do cars, you'll be able to kiss the easy to acquire diesel oil goodbye as well. Summit oil is $20 a gallon now for conventional or semi-synthetic and is good stuff. ZDDP is good for every sliding or pressure point in your engine and even helps the rings seal. No reason to skimp on it in the hot rods just because a roller cam is more forgiving. Besides, it'll be one more box from Summit to look out for on the front porch and who doesn't love that?
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
  #19
Old Mar 5th, 11, 05:13 PM
Brad
First. Thanks Nashville Beth. I called BP and they said the engine is supplied with a new oil pan. They assured me that it was NOT going to be chrome and it was going to match my engine color (chevy orange). That reminds me. If anyone does decide to buy a BP engine it comes standard black. I actually had summit submit my order to BP as a drop shipment. Then I called BP and asked them to paint it orange. They have been very helpful and said they would put it on my order. As for the oil I would absolutely agree with you Steiner. It's definitely a necessity to keep the best oil in our cars. I just think the roller is a little extra insurance.
  #20
Old Mar 5th, 11, 09:49 PM
FFRiccio FFRiccio is offline
Chris
I agree with Steiner...it's always great to find Summit boxes on the front steps. There is a good chance they threw a razor in the box. I haven't bought razors in a couple of years thanks to Summit
68RS Project - taking much longer than expected
  #21
Old Mar 6th, 11, 09:24 AM
JimmyC's Avatar
JimmyC JimmyC is offline
Jim
Hi guys, I can't speak either way on the BP engines. I buy a lot of parts from Summit and agree they are a top notch business. I did however buy a Year One crate engine and have been well pleased with it. It is their Vortec 350/400 package that comes complete with dyno sheets and all the info used for the dyno pull.
Ours showed 425 HP and 450 TQ. Cost to the front door was $3050.00 Works well in my sons little S10.
69 ZZ427 RS resto-mod in progress.
Build Pics ---> http://www.camaros.net/forums/album.php?albumid=727
69 X77 Z28 406 TH400.
69 Pre X RS Z28 in boxes.
67 Chevelle 496 TH400.
64 Nova 396 TH350.
Gold Member #1164
Jim
  #22
Old Mar 16th, 11, 05:39 PM
zdld17 zdld17 is offline
Don
Has anyone use the 396 SBC Blueprint set up? If so, what heads do the use? I see the wording offering a 195CC intake runner head.
Actual bore and stroke?
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
  #23
Old Mar 16th, 11, 08:14 PM
Steiner
They used to use Patriot aluminum heads. I've read somewhere but can't speak as to whether it is true or not that they are the same casting as Pro-Comp and just finished differently. They can usually be had for $800 a set or so.
4.030" bore x 3.875" stroke.
'69 Camaro
500hp/538lbft
www.cmengines.com
  #24
Old Mar 17th, 11, 05:09 AM
Don
thanks Steiner.
Don
TC # 349
  #25
Old Mar 17th, 11, 06:18 AM
Steiner
thanks Steiner.
You bet. Patriot also sells crate engines through Jegs. I don't know how they do it but they sell a aluminum head roller cammed 383 built on a Dart block for $4100. I guess the fact that it only makes 438 lb ft says something about the heads.
'69 Camaro
500hp/538lbft
www.cmengines.com
  #26
Old Mar 18th, 11, 06:33 AM
Brad
I got an email this morning from BP that my engine is done and going to dyno. Does anyone know how to post pictures on here? Would you please email me the instructions?
  #27
Old Mar 18th, 11, 09:24 AM
irish420 irish420 is offline
Sean
its easier if you upload em from a host site, like photobucket or flicker or something like that....or you can upload on tc...when you are making a post scroll down and you will see the upload link to add attachments
1969 - 383, 4sp.,
  #28
Old Mar 23rd, 11, 07:25 PM
Brad
Just updating my post. My engine got Dyno'd today. 442hp at 5300 rpm and 488 ft lbs at 4000. The torque curve is nice and flat! Got to love that! Although I have a long way to go before I am up and running (hopefully by the end of June), I have received exceptional customer service to date. The tech support even helped me fill out Dave's (Dave's Small body HEI) sheet. If you ever see it, it's very detailed. So as of today March 23rd, 2011, I would say that I am completely satisfied but, like I said before, I still have a long way until I am cruising down the interstate!
  #29
Old Apr 18th, 11, 12:02 PM
vambercidw vambercidw is offline
Travis
Hey Brad,
Any updates? You get your motor yet?
  #30
Old May 17th, 11, 07:11 AM
Brad
I'm sorry for not updating this recently. I'm an engineer and for the last several weeks I have been working on site. Trying to start up a power plant is time consuming. Anyway, I did get my engine. It looks great and I was impressed with the packaging. I'm thinking about reusing it to crate up the original 327. Also ordered my TKO-600 from Hurst Drivelines. I should have it in and running by the end of July. I think I am going to try and put it on you tube.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: My experience with Blueprint engines
Location
Location
First Name
Human Verification
