lower vent/kick panel 1969 - Team Camaro Tech
Old Feb 27th, 11, 02:34 PM
40buickcoupe 40buickcoupe is offline
Tech Team
Dennis
Default lower vent/kick panel 1969
AQm I missing something here I cant seem to get the lower kick panel out? What is the trick? I cant seem to get it out past the innser vent that goes into the sheetmetal? Im trying to get both of them out any tips would be great
thanks
Old Feb 27th, 11, 02:45 PM
Fred Ficarra Fred Ficarra is offline
Fred
Default Re: lower vent/kick panel 1969
A crow bar.
After it's out, cut-off the inner flange that makes it so damn hard to remove. Then be sure your roll bar unbolts instead of being welded. A cutting torch down there wouldn't be good.
Oh, on the drivers side you have to unbolt and set-aside the emergency brake assembly. Three bolts, two are next to the vacuum booster. Have fun, like the rest of us.
One owner 69 Camaro,(yep, bought it new)
RS SS Hugger Orange, L88, 4:10's spool, ducted hood, Endura, spoilers.
TH400 (CX) GV OD, 8 track still on console and best et 10.862, 124.24mph 1.478 60'
All with 1960's stuff. (except tires and converter)
+ MT Super Scavenger headers.
1000cfm AED and HD Harold-Lunati SR, 725 lift with shaft rockers too.
http://epitomesrebuild.com/
Old Feb 27th, 11, 03:18 PM
MTN10 MTN10 is offline
Jeremie
It did'nt make it any easier to get out, but yelling at it made me feel better.
Old Feb 27th, 11, 04:47 PM
KevinW's Avatar
KevinW KevinW is offline
Kevin
You really only need to trim the flanges a little on the top and bottom, then the go in much easier! Dennis, You just to keep twisting an pulling
Old Jan 5th, 12, 05:48 PM
bigsteve bigsteve is offline
bigsteve
WTF! how the hell did you get this thing off? I cant get it off and now the sealer is keeping it from sitting flush to reinstall!?
Old Jan 6th, 12, 04:09 AM
KevinW's Avatar
Kevin
I will have to do a write up on this, this spring One of my vent cables came undone, so I have to remove the DR side again to fix. I will have to take some pics as I go
Old Jan 6th, 12, 08:46 AM
bigsteve
did you use a screwdriver ?
Old Jan 6th, 12, 08:59 AM
Sauron67MM Sauron67MM is online now
Scott
Just orient it correctly and it comes right out. It's not a task that can be easily explained because the person doing the removal is responsible for positioning. Once you complete one R&R, the procedure will go easily for all others.
Old Jan 6th, 12, 09:37 AM
bigsteve
thanks
