Brakes work but pedal is too close to floor - Team Camaro Tech
Thread Tools Display Modes
Old Mar 1st, 11, 04:34 PM
bdzee bdzee is offline
Default Brakes work but pedal is too close to floor
Hey guys, I have power disc front and drum rear brakes. My pedal feels good and the brakes work but the physical distance the brake pedal is from the floor and its very close to the accelerator pedal. The pedal is very close to the floor just doesn't seem there is enough travel in it. I've checked everything, even got a reproduction brake pedal (automatic) and it is the same as mine. The master is connected to the bottom hole. Any suggestions. Maybe wrong master cylinder, I remember I had to get the long extention to go into my master cylinder. I look forward to your help on this.
68 convertible 327 Ralley Green, White top, Deluxe Ivory interior, powerglide with white bumblebee stripe
Old Mar 2nd, 11, 12:19 AM
john68 john68 is offline
John
Default Re: Brakes work but pedal is too close to floor
My first thought is the adjustment of the rear brakes?
Old Mar 2nd, 11, 12:35 AM
Luwi67 Luwi67 is offline
Bobby
That sounds like a possible culprit.
Original discs or conversion?
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
https://www.youtube.com/watch?v=1-8uYCabSog
black/black
no radio
Old Mar 2nd, 11, 07:16 AM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is offline
Mike
Disconnect the master cylinder rod from the brake pedal. Then pull up on the pedal and see how far it will go up. It should be up against the rubber stop. Then adjust the rod to the pedal.
Or just look and see if the pedal is touching the rubber stop.
Mike
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/home/pro...maro/allalbums
Old Mar 2nd, 11, 05:58 PM
Mike, the pedal is all the way up. Its maxed out on the frame bracket. Its like it can't go up any more but I know its too low. It was a four speed, is the frame bracket different for an automatic maybe on a 68??
Could I have a drum master cylinder, would that matter?
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Brakes, Suspension & Steering      Current Topic: Brakes work but pedal is too close to floor
Location
Location
First Name
Human Verification
