Torque Specs for Crank Pulley on 327 - Team Camaro Tech
Thread Tools Display Modes
Old Mar 16th, 11, 07:50 PM
cadmanof50s's Avatar
cadmanof50s cadmanof50s is offline
Vic
Default Torque Specs for Crank Pulley on 327
I've been reading through the Service Manual and the AIM for torque specs of the main crank pulley.
I "think" the large center bolt (torsion damper..?) is 60 ft/lbs while the three pulley bolts are 25 to 35 ft/lbs.
Is this correct?
Dumb question: how do I turn the crank manually (i.e. starter not yet installed) once the main pulley has been installed?
Vic
Vic Brincat
1968 Camaro RS Convertible
383 SB, AFR 195 Heads, 670 Holley, Doug Thorley Tri-Y Headers, Lunati "Voodo" roller cam, Weiand 8150 Intake, Scorpion Edurance Rockers, 700r4, Eaton Posi with 3.73 gears, Front Discs, Summit Legend 5 - 15" with BF Goodrich TAs
Old Mar 16th, 11, 08:27 PM
Melrose RS Melrose RS is offline
Tom
Default Re: Torque Specs for Crank Pulley on 327
Are you sure it has a center bolt? My 327 doesn't...
'67 rs - ordered new by my Grandfather
327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed.
the Melrose rs - L30 327/275hp
Old Mar 16th, 11, 08:32 PM
1968RallySport's Avatar
1968RallySport 1968RallySport is offline
Daryl
I think they started using a bolt in '68?
Old Mar 16th, 11, 08:35 PM
Tom
Oh, that could be. LJ vs SJ.
If you have the bolt installed and you want to turn over the engine, I'd just pull the plugs and spin it by the center bolt.
Old Mar 16th, 11, 09:01 PM
Tom
An old Clymer manual I have here says 60 ft-lbs for small blocks.
Old Mar 16th, 11, 09:10 PM
Vic
Thanks folks...!!
Vic
Vic Brincat
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Torque Specs for Crank Pulley on 327
Location
Location
First Name
Human Verification
