| Team Camaro Tech Current Topic: Fuel pressure issue? | ||
| Engine General Engine Discussion. |
When i start car it has 12psi but over 10-15 minutes of warm up it creeps down to 7psi. I have a fuel cell that is vented out the top, fuel line goes out of cell into holley blue pump into a fram filter, 8an line all the way to front engine compartment into a 8an to 6an union, then into holley fuel pressure reg. mounted at carb with 2 hard lines coming out to carb. Do i need a return line to tank or do you think it could be a voltage issue. Thanks
| Sponsored Links | ||
Advertisement | ||
Try another gauge, first,
Then, unscrew the gauge, add a length of line to remote locate the gauge away from heat. If gauge is liquid-filled, might try a 'dry' gauge, just a regular type.
Give a man a rescued dog for the health of his soul. Two little words - Yes and No - require the most thought. Other stuff: http://www.flickr.com/photos/everettwn68 |
last time the fuel filter was changed?
BILL D. JOHN 3:16 SEMPER FI if you have a bbc in your 1st gen 67-69 camaro click on the link below and enjoy the veiw and post yours up!! ![]() http://www.camaros.net/forums/showthread.php?t=169199 if you have an all original 1st gen camaro 67-69 click on the link below and enjoy the veiw and post your up!! ![]() http://www.camaros.net/forums/showthread.php?t=179697 |
ill try a regular gauge and the fuel filter was just changed 300 miles ago. |
was fuel pressure gauge. liquid filled is no good....thanks
| Sponsored Links | |
Advertisement | |
