Fuel line pump to tank - Team Camaro Tech
Old Apr 13th, 11, 05:41 PM
DT DT is online now
Donny
Default Fuel line pump to tank
Hey guys, I was just looking into a new OEM fuel line pump to carb. Anyone know where the line actually ends towards the rear?? Is it by the tank?? Do I have to remove the tank to install?? Thanks.
396 X66 LeMans Blue, M20, 373 ...
Old Apr 13th, 11, 06:31 PM
JohnZ JohnZ is offline
Team Member
John
Default Re: Fuel line pump to tank
Nope, you don't have to remove the tank; there's a rubber hose connection between the sender pipe on the tank and the end of the main fuel line on the rear rail.
JohnZ
CRG
'69 Z/28 Fathom Green
Old Apr 13th, 11, 06:32 PM
DT DT is online now
Donny
Thanks John. Boy they rigged this line up, LOL.
Old Apr 13th, 11, 06:42 PM
Steiner Steiner is offline
Steiner
If you've got subframe connectors it's going to be interesting. Was just thinking about that the other day....wonder if the best thing to do is cut and flare the line to make it a two piece.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Apr 14th, 11, 12:18 PM
DT DT is online now
Donny
No Steiner, stock frame. It looks like someone made it a two piece though because it has what looks like a union in the line.
Old Apr 14th, 11, 12:24 PM
HwyStarJoe's Avatar
HwyStarJoe HwyStarJoe is offline
Previous owner of mine bought a coil of 3/8 copper water line and ran this squiggly, twisty line from the tank to the pump.
I kept the copper line as a memento.
STREET MACHINES OF ROCHESTER
SEMA ACTION NETWORK
UNITED SERVICES ORGANIZATION (USO)
Old Apr 14th, 11, 01:41 PM
DT DT is online now
Donny
Haha, you just can't make this stuff up!
Old Apr 14th, 11, 01:52 PM
rogerh rogerh is offline
Here is a few pictures i took before my restoration. It shows the layout and clips.
Click image for larger version
ID:	21834   Click image for larger version
ID:	21835   Click image for larger version
ID:	21836   Click image for larger version
ID:	21838   Click image for larger version
1967 Camaro SS/RS 350/295HP Coupe. First and only owner.
Old Apr 14th, 11, 05:19 PM
DT DT is online now
Donny
Roger, It doesn't get any better than that !! Excellent pictures, thanks.
Old Apr 14th, 11, 06:07 PM
Steiner
I'm surprised you didn't sell it and buy yourself another Little Debbie.
538 lb-ft - 500 hp
www.cmengines.com
