Choice of heads - supercharged engine - Team Camaro Tech
Old Apr 17th, 11, 05:20 PM
jumpstart jumpstart is offline
Default Choice of heads - supercharged engine
Is there a clear winner between these heads on the same SBC 355cu., BDS 6-71 supercharger -
World Products Sportsman II iron heads, 200cc intake ports, 69cc exhaust ports
Edelbrock Performer RPM aluminum heads, 185cc intake ports, 65cc exhaust ports
Both have same valve sizes and combustion chambers. I have both sets of heads, just not sure if it's worth it to pull off the iron heads to try the aluminum.
Old Apr 17th, 11, 07:58 PM
67YenkoJC 67YenkoJC is offline
Team Member
Jason
Default Re: Choice of heads - supercharged engine
Well, the aluminum heads will serve as weight savings, cooler temps and a few more degree's of timing and less detonation. About the only way to tell the difference in the iron heads will be at the track. there might be 10-20 hp difference in the two, but the 6-71 is going to be pumping so much air in, you're going to be hanging on for dear life and no worring about head flow #'s at the moment Iron heads wont blow gaskets as easy as aluminum's will due to head lift.
1967 Camaro Yenko Pro Touring Tribute (being built)
http://www.camaros.net/forums/showthread.php?t=178571 Follow my build
Old Apr 17th, 11, 08:21 PM
camaroman7d camaroman7d is offline
Royce
Very tough question and not enough info to really make a choice. What kind of fuel do you plan to run? What is the compression?
Royce (NO XQSSS) Bradley
www.facebook.com/driveyourjunk
http://www.youtube.com/watch?v=DSLsGgDjFXE
(brief sound/video clip, 3 1/2" exhaust through Borla Sportsman mufflers)
Old Apr 17th, 11, 08:33 PM
Eleanor's Nemesis Eleanor's Nemesis is offline
Michael Gekko
One thing to consider is if you are going to beat on it a lot if you have a failure that damages a head aluminum is easier to repair.
1968 Camaro NHRA/IHRA SS/C 'Super Stocker' 396/Jerico
1968 Street/Strip Camaro 350 w/PG
1968 Caprice NHRA/IHRA Stock ELiminator O/SA 327-250 HP
Land of the Free Because of the Brave
It Takes a Long Time to Grow Old Friends
