Oil pressure line?? - Team Camaro Tech
Thread Tools Display Modes
Old Apr 29th, 11, 02:43 PM
Speedjester Speedjester is offline
Hector
Default Oil pressure line??
Does anyone make a copper or steel line for the mechanical oil pressure gauge..
Had a real close call today and need to find a way to shield the plastic line or change it out entirely... It is less than half inch from the header...
Thanks in advance..
68 Camaro Coup, BBC ,2457 headers, th400 , ford 9", Hotchkiss connectors,
Old Apr 29th, 11, 02:50 PM
john68 john68 is offline
John
Default Re: Oil pressure line??
You can get them in anything you want,
Old Apr 29th, 11, 02:51 PM
Steve69SS396's Avatar
Steve69SS396 Steve69SS396 is offline
Steve
http://www.summitracing.com/search/D...?Ns=Rank%7cAsc
'69 Camaro - 427 SBC Dart Iron Eagle 9.325" block, Cola crank, Lunati 6" Pro Mod rods, JE pistons (13.8:1), Hellfire rings, AFR 245 heads, T&D steel body shaft rockers, Jesel belt drive, custom ground 4-7 swap solid roller 274/286 @ .050" with .704" lift, Dart single plane, 1050 Dominator, Stef's #1705R oil pan, NOS big shot, Lemons 2" primary 3-1/2" collector, Coan 9" converter
Old Apr 29th, 11, 02:52 PM
Z15CAM Z15CAM is offline
Ron
Do NOT use Copper or Nylon in the Engine Compartment. I can't say Steel is any better. I recommend Hi-Pressure Hydraulic Rubber Hose to a 3 Outlet Bronze Adapter mounted in the Firewall then run Nylon to the Mechanical Cab Gauge (continue with the Hydraulic Hose under the Dash if Room Permits it). Use the 2nd Bronze Engine Compartment outlet to mount the Idiot Light Oil Pressure Sensor.
Copper, Nylon and Steel Oil Lines Break in the Engine Compartment as the engine Torques against the Firewall & Flex the Oil Line. Been there done that and learned my lesson years ago.
Z15CAM - There was a Viper in my Rear View
This was my 70 1/2 Z28
http://www.flickr.com/photos/28082975@N04
Old Apr 29th, 11, 03:27 PM
Hector
Will the 1/8 Cooper line use the same fittings as the nylon line I have now..
I don't think steel braided will last this closet the header
Old Apr 29th, 11, 04:26 PM
rj68RS rj68RS is offline
Russ
Do you have any tractor or hydraulic repair companies near you ? If so, take the fittings to them and they can make a custom line for you to your exact specs. It would be a high pressure rubber line with a braided cover. I do this all the time with oil, coolant, and hydraulic lines for my motor coach. I've paid as low as 25.00 and as high as 150.00 depending on length and whether I wanted straight, 90, 135, 180, or swivel fittings.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
Pics: my drop top driver
Old Apr 29th, 11, 05:31 PM
mark191 mark191 is offline
mark
Is your line coming straight out of the block above the oil filter? If so use a 90 degree fitting out of the block and run the braided autometer line
68 originally ss (straight six) 406,Afr210,Bullet solid roller,rpm airgap,QF750,th400,3.73 Eaton posi.11.02 @ 122.74
Old Apr 29th, 11, 08:04 PM
Orange68SS Orange68SS is offline
Bill
I just went to an auto part store and had a copper line made up for me with all of the fittings.
68 SS Camaro - 468 BB, Tremec 5 Speed, Wilwood Brakes, Curry 9 inch (370 gear)
http://s593.photobucket.com/albums/tt17/orange68SS/
Old Apr 29th, 11, 08:28 PM
Geezer Geezer is offline
Napa has them in a kit but it's a fixed length.
Ron
The Junk Yard Dog
An exercise in interchangeability on a Well optioned 67 SS 350 vert.
Old Apr 30th, 11, 03:27 PM
zdld17 zdld17 is offline
Don
Did copper and plastic for 30 years but when thought of the copper taking the vibration and plastic possiabily melting in high heat, I went to a small steel braided line from the motor thru the firewall into the gauge. It may be an over kill but at least I know its safe.
Don
TC # 349
Zdld17:69 Z/RS,306, NOR141111, 9N554XXX, 12A, X3G, 59/59,723, AFR 195,CCC282/290HR, TKO 600, BU1122B1E
http://s102.photobucket.com/albums/m...t=115_1577.jpg
  #11
Old Apr 30th, 11, 03:47 PM
Hector
Went to the speed shop picked up the copper line... Attached to block coiled the line three times to help with vibration.. then through grommet in firewall ..
Noticed when I first started it with the new copper line that the gauge read 20lbs for about 20 seconds before shooting up to the usual 65..is this normal until the air clears the line or is the gauge on it's way out??
  #12
Old May 6th, 11, 10:31 AM
JohnZ JohnZ is offline
Team Member
John
Copper tubing is a BAD idea for an oil pressure line; it will work-harden with vibration and eventually fracture - GM never used it. GM used copper-plated steel lines.
Paragon sells a complete kit for big-blocks with a coiled copper-plated steel line and the fittings for both ends, listed for '67 Corvette usage.
JohnZ
CRG
'69 Z/28 Fathom Green
  #13
Old May 6th, 11, 11:33 AM
Notalent Notalent is offline
Brandon
Say no to copper and nylon. You want a good steel braided line. This is what ya want and it will come with different fittings. I swapped mine from a nylon line which the car came with and the fittings this came with matched up.
http://www.summitracing.com/parts/ATM-3228/
71 Chevelle 496 Stroker Hyd Roller 675HP, TH400 3500 Stall, 3.73 12 Bolt.
ATK HP ENGINES
WWW.HIGH-PERFORMANCE-ENGINES.COM
Custom Built Street-Strip-Racing Engines
  #14
Old May 6th, 11, 11:35 AM
go2fast go2fast is offline
Jim
What he says ^^^
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Engine      Current Topic: Oil pressure line??
Location
Location
First Name
Human Verification
