| Team Camaro Tech Current Topic: What do you monitor with gauges in your car? | ||
| Camaro Tech General Tech Area For best results use specific forums |
I am planning to install a Covan 6-gauge panel in my 67 and I am trying to decide which gauges I should get. I am planning on using the Ultra-lite II gauges. I know I want MPH, RPM, and Oil Pressure. What should I use for the final 3? I am thinking water temp, fuel level, and volts. But maybe I should have oil temp or fuel pressure instead.
What do you guys think? Matt
Matt 67 RS, 406 small block, TKO600, Moser 12-bolt (3.73) |
| Sponsored Links | ||
Advertisement | ||
Can't argue with those choices. Another possibility is an O2 meter.
69 RS, Hugger orange/black, Deluxe interior, Sony AM/FM/XM/CD, PS & PB. 355, forged pistons, Eagle rods, balanced, Iron Eagles, 9.4:1 CR, .038 quench, XR270HR Cam, Performer intake, SMI Stage 2 Qjet, Thorley Tri-Ys, TCI 700R4, 2400 stall, 3.42 posi |
Well, fuel level and water temp are a given.
An Amps gauge is a give or take, since all it tells you is if your charging system is working. You'll know if it's not when the battery dies. ![]() I'd put an A\F meter gauge in it's place like Mark suggested.
*---------------------------------* STREET MACHINES OF ROCHESTER SEMA ACTION NETWORK UNITED SERVICES ORGANIZATION (USO) |
Covans
-Speed -Tach -Boost/vac -Fuel pressure -O2 -Fuel gauge Console -Temp -Volts -Oil Pressure -Trans temp
1968 Camaro Convertible ,350 TWIN TURBO , PTC 3000 stall, Hotchkis TVS kit / Subframe connectors, Caltracs, 9" rear, Street Star wheels (P275/40ZR17 / P235/45/17) , Electric cutouts. [B] |
I like your choices. In a perfect world, an acccurate vacuum gauge would be worthwhile, but it would be down the list, below the essentials; MPH, RPM, Fuel, Oil Pressure, and Coolant Temp.
For the 6th pod, yeah, I'd probably go with either amps or volts. Most like volts but amps is more informative. Oil Temp is worthwhile. All Vettes since the mid-80's include an oil temp gauge. You want the oil's temp to be just over 212~ degrees to cook out (vaporize) moisture and other blowby gunch. FWIW |
I have AutoMeter II gauges as well. Speedo/RPM up front. Volt/Temp/Oil Press/Gas on the console. I also have 3 gauge cluster mounted of the bottom of the dash on left side between the e-brake lever and steering column with Tranny Temp/O2 wideband/O2 wideband (two O2's, left/right exhaust)
your not looking for stock so I would skip the amps and go with volts. Better to know what in the battery system is doing then to know just that the alt is sending out juice.
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear http://69pace.blogspot.com/ |
I use to have a little hotrod with an Aluminum tank in the trunk and only a sight glass. I ran out of fuel several times. A fuel gauge on the dash is nice to have.
Ron The “Junk Yard Dog” An exercise in interchangeability on a Well optioned 67 SS 350 vert. |
I'd stick with the gauge choices you made, including fuel, water temp and voltage. The other ones are cool but not sure how much value they add.
AF ratio as an example: unless you have a max built machine and may have a fuel delivery problem, seems more like a set up tool than a monitering gauge to me. Assuming a good set up and adequate fuel delivery, why would that change? Same with Vac? They could give information that will avoid a problem I guess, just seems they would be much less likely problems than the other 6 you have mentioned. Maybe more information about the car you are installing the gauges on would help.
69 Pace Car and 69 Hard top |
x2
#11
Right now
Stock dash: Speed Fuel Tach on column: RPM Auto Meter console kit: AFR Vacuum Oil pressure Water temp Moving everything to a car with in dash tach and clock with factory console gauges. Going to move my Auto Meter console over so I'm replacing the clock with a reproduction center fuel gauge. I had purchased a fuel gauge to replace the vacuum gauge but Year One had one of their 30% off sales so I went ahead and got the center fuel gauge and bezel.
'69 Camaro X11 Street Car Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III TKO-600 - Moser 3.42 - Detroit Truetrac 538 lb-ft - 500 hp www.cmengines.com '69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10 '02 Z/28 vert - stock |
#12
Gauges in most cases are just pretty ornimemts...
Hard in or on a long trip idiot lights for critical stuff like oil press, water temp, ign useful orniments Fuel oil pressure Volts vaccuum Rpms water temp. O2 as a gauge, impressive but not responsive enogh to be of any real tuning or montoring use...handy to pick up a spark plug dieing ..thu vac will do that to...good bragging factor thu. A clock in case u dont wear a watch or dont have a cell....even so I dont have either and still doing have a use for a clock...
My Spelling is not incorrect...it is creative http://www.kakariki.net/camaro/Meguiars.jpg http://www.kakariki.net/camaro/BeauRep.jpg http://www.kakariki.net/camaro/xmasparade.jpg http://www.kakariki.net/camaro/trailer.jpg |
#13
If you know how to read a vacuum gauge its one of the most useful to have.
I had a car that held 17ins of vacuum, one day I started the car and it was running different and only had 12 inches of vaccum and I blamed it on bad gas. The next day the vac was at 5!! I pulled the PCV valve and nothing changed, I tried to pull the oil cap in the opposite valve cover and it wouldn't come off with the car running???? I shut the car off and then the cap came right off. Started the car and I had 17ins of vacuum again. It was the old, used valve cover chrome air breather that was stopped up with a big piece of dried oil and stopped the engine from breathing. It would have been awhile without the vacuum gauge trying to figure out that problem. When I use the 3 pod gauge panel I always put the vac gauge right in the middle hole.
1981 Camaro, 357ci, super T-10, 456 posi. |
#14
Mines simple.
MPH RPM Fuel Water Temp Volt Oil Pressure
1968 Arctic White Camaro 400 SBC M4 LS1 Brakes/IROC Box/Speedtech UCAs/Hotchkis Springs and Bilistein Shocks Coming Soon: T56
#15
When cursing, a side from the Speedometer, I monitor a Full Sweep Manual 80 PSI Oil Pressure Gauge (It's a good as the Tach) another thing would be a Vacuum Gauge as you can cruise at the highest Vacuum for best Gas Mileage and it quickly picks up Vacuum problems.
Z15CAM - There was a Viper in my Rear View This is my 701/2 z28 http://www.flickr.com/photos/28082975@N04 |
| Sponsored Links | |
Advertisement | |
