| Team Camaro Tech Current Topic: When installing timing chain and cam in 350 chevy | ||
| Engine General Engine Discussion. |
When installing a cam and then aligning the timing chain marks in a 350 chevy does the #1 piston need to be at TDC when this is being done?
Or does that only matter when you are stabbing the distributor in. |
| Sponsored Links | ||
Advertisement | ||
Yes. #1 TDC
396 X66 LeMans Blue, M20, 373 ... |
Yes. #1 and #6 will be at TDC. When you align the gears "dot to dot" as in the picture, be aware that #6 will be at TDC on the compression stroke and #1 will be at TDC on the exhaust stroke. Install distributor accordingly.
69 PJ Convert, RS added, ZZ383+, 2004R, 3.73 posi, C6/LS1 Brakes, etc "Big hitter, The Lama, long." Carl Spackler |
So the distributor rotor would actually be pointed at #8 piston then if the timing chain is installed as shown or 180 degrees out?
No, rotor should face the #1 piston.
All you need to worry about is getting the two dots to align.
There's a dowel pin on the cam and the crank has a keyway. If the dots are lined up you can't screw it up. Then get your #1 piston on TDC compression stroke(your timing mark on the crank should be close to zero). Drop the distributor in and the rotor should be pointing slightly before the #1 position (it rotates clockwise). |
sprocket marks dot to dot as shown will be # 6 firing !
both marks at 12 o'clock will be #1 firing ! You want to drop in the distributor to match the above.
69 Camaro -originally a LM1 car. 327, Edelbrock E-streets, hooker, DUI performance distributors, ultradyne cam, stewart, TRW etc. Vintage Air, AGR steering, Corbeau GTSII seats, 700R4 TPI transmission, 12-bolt w/Eaton 4.11:1 |
I always use about 10 degrees before TDC ( advanced) by the timing mark because you are going to have to advance the disti from zero to get it to run well anyway.
'67 rs - ordered new by my Grandfather 327 L30, K-K, Deluxe int, tach & gauges, 12 bolt posi, 4 speed. (And an 8 year old riding shotgun. )the Melrose rs - L30 327/275hp |
If you line the gears up dot to dot, set the dist to #6, the service manual explaines in detail??? |
Yes, I was thinking 12 o'clock position. (explains)
| Sponsored Links | |
Advertisement | |
