| Team Camaro Tech Current Topic: 79-82 steering column hi/lo beam repair | ||
| Electrical & Wiring Troubleshooting electrical. |
I was testing some of my electrical equipment since I am installing all new wiring in my car. In my 69 camaro it has a steering column with the hi/lo beam switch in it. It looks like a column out of a corvette. I think the clicker switch is broken. How hard is it to repair this issue?
| Sponsored Links | ||
Advertisement | ||
Well I verified that the hi/lo in the column must be broke. I unplugged the wiring from the column and installed a foot dimmer switch. Hi/lo beams worked fine.
Switch for high beam is at bottom of column. The "click" is down there. The pivot assembly up top is a common replacement item on these columns. If you have a lock plate depresser tool it's doable. It's been quite some time since I done one.
Jeff |
After looking the tool up on the web. I think I have one in my tool box. Forgot that I even had it. Probably 4-5 yrs since I would have used it. Will I have to take any upper column housing off? Last edited by tgifford5; Jun 24th, 11 at 09:29 AM. Reason: Added question. |
| Sponsored Links | |
Advertisement | |
