68 quarter window chrome trim - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Jun 29th, 11, 03:10 AM
nev68 nev68 is offline
Nev
Default 68 quarter window chrome trim
2 questions.
1. How do you remove the chrome trim from a 68 Camaro quarter glass?
See highlighted part in the photo
2. If this part is adhered to the glass, what type of adhesive is used?
I hope someone can help.
Rgds,
Nev
Almost finished (?) 68 Camaro
383 stroker
T350
12 bolt Moser
Old Jun 29th, 11, 06:21 AM
69-Pace's Avatar
69-Pace 69-Pace is offline
Default Re: 68 quarter window chrome trim
Similar thread here: http://www.camaros.net/forums/showthread.php?t=197100 with respect to getting the chrome to install so maybe a reverse engineering process. Looks like people have used a ton of different methods. Is your factory installed? You might pop over to CRG forums and see what original material was used to affix it .
1969 Z11 Pace Car - L48 350cid/300hp - 4 Speed Muncie 12 bolt rear.
Finally back on the road after being stranded in the garage for over 20 years. Follow her progress back to the road http://69pace.blogspot.com
Old Jun 29th, 11, 07:07 AM
Mike68RS Mike68RS is offline
Mike
To remove, tape up glass to protect it, if you are going to reuse it. Then use a block of wood and slowly tap the molding off. Originally the moldings were pressed on the glass with a piece of rubber weatherstrip or what I call glass tape.
Mike
Old Jun 29th, 11, 08:53 AM
Lexlas's Avatar
Lexlas Lexlas is offline
Lex
Funny, i can't get mines to stay on, lol .. It keeps falling off on it's own - dont' roll down the window, lmao !
http://www.flickr.com/photos/10729028@N03/
68 Camaro / 400 ci / 3.73 10 /
Edelbrock Performer Series 600 cfm no. 14054
Edelbrock Performer EPS Intake Manifold 27014
98 GMC Suburban / 454 V8 / K2500 4x4
Old Jun 29th, 11, 01:10 PM
Mike
Use urethane glass adhesive. It WON"T come off.
Mike
Old Jun 30th, 11, 05:10 AM
Nev
I only want to replace the scratched glass.
Is it better just to buy the entire assembly with glass and trim?
Rgds,
Nev
383 stroker
T350
12 bolt Moser
Old Jun 30th, 11, 05:53 AM
69-Pace's Avatar
Is the current glass beyond polishing out the scratches?
I think Mothers and a few others have DYI glass repair/polishing kits out there. Saw one on Musclecar a while back but don't remember the vendor - think it was part of project Red Sled - so it should be listed on powerblocktv.com
Or check a few of your local glass shops. They should be able to preserve your numbers glass and might be so much cheaper then replacement glass.
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: 68 quarter window chrome trim
Location
Location
First Name
Human Verification
