New dash carrier. Support bar or no support? - Team Camaro Tech
Old Jul 5th, 11, 09:22 AM
tgifford5 tgifford5 is offline
Team Member
Ted
Default New dash carrier. Support bar or no support?
I have a new dash carrier for my 69. When I recieved the new dash it had kind of a support bar/strap across the back between the two center gauges. Is that there for shipping purposes (support)? Or should it be removed before I install it into the dash? My old one, when removed, did not have it on. So that is why I am asking.
Old Jul 5th, 11, 10:45 AM
KevinW's Avatar
KevinW KevinW is offline
Kevin
Default Re: New dash carrier. Support bar or no support?
It is there for extra support when the center is cut for a clock or center gas gauge. I would leave it in any case.
Old Jul 5th, 11, 01:36 PM
Team Member
Ted
The issue then is that you can't flex the dash enough to get the mounting holes to line up.
Old Jul 6th, 11, 08:46 PM
6781camaro's Avatar
6781camaro 6781camaro is online now
Todd
Try lining up the dash panel mounting holes first--but don't tighten those screws all the way down yet.... then-- install that cross bar loosely... finish tightening the mounting screws and then go back to the cross support bar and tighten that to finish.
If not, it sounds like your upper dash panel may have been replaced at one time and may not have been aligned perfectly to allow the holes to line up. You could also always widen the holes as a last resort.
'69 Frost Green V8 Coupe-Building now!
'68 Sequoia Green V8 Coupe--Building now!(too)
'68 6 cyl Coupe, '75 LT350, '79 Berlinetta V6, '79 Z/28, '80 Z28, '81 Z/28, '82 Berlinetta V8,'84 T-top V6, '89 RS V8, +finally a '92 Z/28 T-top in Purple Haze Metallic--...ALL SOLD
Helpful build pics+tips from my restoration:
http://s299.photobucket.com/albums/m...ro%20%20SS350/
My build thread:
http://www.camaros.net/forums/showthread.php?t=146455
Old Jul 8th, 11, 06:23 PM
Motown 454 Motown 454 is offline
Wayne
My original car had it from the factory.
Wayne
69 Camaro SS/RS Finally Home!. Mini tub, Fab 9 31 spline . 454 Motown sb 600/575tq Viper 6spd. 3" Magnaflow. C6 Z51 brakes. AirRide G bar Rushforth Livewire 18x8 19x12
http://www.lateral-g.net/forums/show...ghlight=FNQUIK
