Spark Plug Reach - Team Camaro Tech
Old Jul 13th, 11, 11:43 AM
Dusk_Blue_Z Dusk_Blue_Z is offline
Nick
Default Spark Plug Reach
I've got a zero-decked, 12.5cc domed piston short block. On top are 492 heads. I bought a set of Accel 437s plugs (with the same reach as the stock plugs, 0.375). Unfortunately, they didn't fit on the heads I've got.
I picked up a set of Accel 8199. They have a reach of 0.46. Do you think that these plugs reach too far and I'll have clearance issues?
Thanks, Nick
Old Jul 13th, 11, 12:28 PM
97Z4C 97Z4C is offline
darrell
Default Re: Spark Plug Reach
that is alot of compression with 492 heads--definitly would be looking at a autolite plug not accel--i am not certain and i hope john or someone else chimes in-i think the r45ts in ac works on that head and would cross it over to autolite -definitly index your plugs with ground strap to top or gap slightly facing exhaust valve
Old Jul 13th, 11, 12:29 PM
darrell
also with that compression go alittle cooler like r42
Old Jul 13th, 11, 12:49 PM
Nick
Yes, if there's a better solution, by all means suggest it. For one reason or another, I read a lot of posts where the Accel shorty plugs were highly suggested.
Old Jul 13th, 11, 01:01 PM
Nick
While we're at it, can someone suggest a set of plug wires? Thanks.
Old Jul 13th, 11, 01:10 PM
DOUG G DOUG G is offline
RedЯuM
http://www.autolitesparkplugs.com/se...nufacturerID=5
See if that helps you with the reach and cross overs.
Did you check the reach with the heads off to see where they set depth wise ?
With a dome and too much reach....you could have issues
68 Camaro~ LSx
RedЯum <-Pics
http://www.youtube.com/watch?v=Of8WV...ature=youtu.be <~More here
Old Jul 13th, 11, 01:43 PM
Nick
Is there a general rule of thumb or equation for reach? This is something I probably shouldn't be guessing at.
Old Jul 14th, 11, 03:56 AM
darrell
well--you want the threads to end up at the end of head and not entrude into cylinder and you dont want extended reach plug-let me chek, i might have one of these heads laying around--accel is not the plug for high compression in my opinion unless you have to because of header issues (plug too close to header)--msd is the only wires --as many on here will tell u- taylor is no good
Old Jul 14th, 11, 04:46 AM
darrell
autolite 25 will work-do you have the angle plug 492s -is this why you want a shorty plug--the angle or straight plug 492 heads only flow 161cc intake stock--just saying with this amount of compression
Old Jul 14th, 11, 06:39 AM
Nick
Yes, I have the angled 492 heads. They've had some work done to them. Found out that my 186 heads were junk, so got the 492's in a pinch (trying to get the engine fired this Sunday).
I bought a set of the AC R42TS, but they aren't short enough. The Accel 8199's fit pretty well (in terms of clearing the headers). I have them gapped at .035, is that ok for the cam break in period?
I'll look up what MSD makes in a black wire that fits over the valve caps. Thanks for your help Darrell.
Old Jul 14th, 11, 07:02 AM
Nick
It doesn't look like MSD makes a custom fit product for my car. Are univeral wire kits the best alternative?
Old Jul 15th, 11, 06:45 AM
darrell
the universal wires will work--if you get the ones where you have to cut the wires yourself, take the time and crimp the ends correctly--the shorty plugs will work for now-but i really dont like them for racing--.045 gap if you have electonic ignition--(hei,msd,unilite ect.)--.035 gap is for points stile dist
Old Jul 15th, 11, 10:31 AM
Nick
I ended up getting a set of Prestolite wires. My only concern is two boots are nearly touching the headers. Do you know if those fabric-type bootguards would prevent the boots from melting?
I guess I'll find out how everything is going to dance together soon enough. Thanks for your help Darrell.
Old Jul 16th, 11, 02:51 AM
darrell
i have doon the same set up-alota work but dented the header a bit to clear with the backside of a ball pen hammer-well it worked- let us know how it sounds
