What oil for 383 - Team Camaro Tech
Old Jul 21st, 11, 07:56 PM
emperor91108 emperor91108 is offline
Greg
Default What oil for 383
I have new 383 stroker engine with a roller cam. So far I have been using 15-40 Rotella. I would like to start using a synthetic oil. Should I use 10-30, 10-40(hard to find), or 20-50. The 10-30 seems like the easiest to find followed by 20-50.
68 383, TH-350, 3.55 Eaton Posi, Holley SA 770, RPM Air Gap, World Sportsman II, ISKY Roller Cam
Old Jul 21st, 11, 08:29 PM
97Z4C 97Z4C is offline
darrell
Default Re: What oil for 383
in all my 383s and most others--i use 10-30 fully synthetic valveoline
Old Jul 22nd, 11, 12:05 PM
keithl1967 keithl1967 is offline
Keith
I have a 383 roller, and use conventional valvoline 20-50...
Keith
1967 Camaro
Bought it in 1994:
230, PG w/ 314K miles!
Today:
383, Dart Iron Eagle heads, Eddy Vic Junior, Holley 750 DP--450HP+
Muncie M-20
GM 8.5, 3.73 posi
Old Jul 22nd, 11, 07:02 PM
Steiner Steiner is offline
Steiner
Rotella T6 5W-40 has been getting good reviews on the bitog forums. Still has over 1000ppm zinc for now which is good even with a roller.
'69 Camaro X11 Street Car
Dart 400 - AFR-195's - Comp HR 224/224 - Powerjection III
TKO-600 - Moser 3.42 - Detroit Truetrac
538 lb-ft - 500 hp
www.cmengines.com
'69 Camaro X44 Beater - SFT 327 - M20 - Moser 4.10
'02 Z/28 vert - stock
Old Jul 22nd, 11, 07:29 PM
quickboat quickboat is offline
jim
^^^^^I'm using the T6 also, great stuff!
67 RS Deluxe Int. A/C car
TKO-600
400 4 bolt block .03 over
Ported 215 Pro1 Platinums
Forged/balanced 400 crank, pistons, 6" rods
286HR cam w/1.6 rckrs LS1 beehives
15x8 Rallys, Gulstrand, Konis, Eibachs, 1" Swaybar
IROC s/gear, 4 wheel discs
Old Jul 22nd, 11, 08:46 PM
Steiner
Good to know. I've had a couple gallons sitting in the garage for a while but have a case of the Summit Racing semi-synthetic 10W-40 to burn up.
538 lb-ft - 500 hp
www.cmengines.com
Tags
oil 383 roller cam
