Core support bushings on 69 Camaro. - Team Camaro Tech
Body Shop Paint & Body Forum
Thread Tools Display Modes
Old Jul 31st, 11, 12:10 PM
1320King 1320King is offline
Default Core support bushings on 69 Camaro.
I tried to search this topic but did not find anything. How do these core support bushings install on the core support and subframe?
Is that metal sleeve on the bushing in the far right of the pic supposed to slip inside of the subframe hole???. If so then i will need to take a file to either the bushing or the subframe hole to make it bigger so that metal sleeve will fit inside.
Here is a pic of the set.
Old Jul 31st, 11, 01:05 PM
67camaroprotour 67camaroprotour is offline
Tech Team
Brandon
Default Re: Core support bushings on 69 Camaro.
Piece on left goes through hole in core support from bottom then bushing on right fits over it on top. Bolt goes in from top with washer and nut inside frame rail.
Brandon
1969 Camaro Z28
1968 Camaro Protouring/ Project
"I'm all jacked up on Mountain Dew"
Old Jul 31st, 11, 01:38 PM
DjD's Avatar
DjD DjD is offline
Dennis
I posted this a while back, it should help.
Originally Posted by DjD View Post
This is for a '69, I would expect it's the same for '67 but you might want to check the AIM...
Stacked it goes like this;
Core Support .. Center Mount ..... Rear Mount
bolt ............... body (cage nut) .... body - (cage nut)
washer .......... cushion asm ......... cushion asm
cushion ......... sub-frame ............ sub-frame
core support .. cushion ................ cushion
cushion asm .. washer ................. washer
push nut ....... bolt ...................... bolt
frame
washer
lock washer
nut
There are 3 diff cushion asm sizes used and 2 diff cushion sizes used. Be sure you got the right pieces in the right places.
That reads down from the top, the cushion assembly is the one with the sleeve in it and it goes up into the bottom of the core suppport and if it were factory there would be a push on clip (push nut) that holds everything to the core support. Then the whole assembly sits on the subframe with the bolt going through and getting a washer, lock washer and nut.
...Dennis
www.camaroslimited.com
Old Jul 31st, 11, 04:31 PM
I am not quite following your stackable guide.
Are any of the bushings supposed to fit on the inside of the frame rail?
Do the bushings sandwich the core support and they all sit on top of the frame rail?
Old Jul 31st, 11, 04:39 PM
Ahhhh hah....I think I see what you are talking about. Muchas gracias guys!
Old Jul 31st, 11, 04:41 PM
Tech Team
Brandon
Sandwich the core support on top of frame. Nothing below the framerail but washers and locknut.
Brandon
1969 Camaro Z28
Old Jul 31st, 11, 07:40 PM
Steiner Steiner is online now
Steiner
Brandon already listed it but here's the instructions
http://static.summitracing.com/globa.../ens-17235.pdf
'69 Camaro
Dart 400-AFR 195-224/224 HR-Powerjection III TB with F.A.S.T. Sportsman XFI
TKO 600-Moser 3.42-Detroit Truetrac
500hp/538lbft
www.cmengines.com
'69 Camaro Beater-SFT 327-M20-Moser 4.10-sold
'02 Z/28 vert-stock-sold and totaled
Team Camaro Tech > First Generation Camaro Info and Tech - 1967- 1969 "Where it all started" > Body Shop      Current Topic: Core support bushings on 69 Camaro.
Location
Location
First Name
Human Verification
